Hello Guest it is June 10, 2026, 06:16:01 PM
Author Topic: y-axis driven by two motors  (Read 8937 times)
« on: May 18, 2011, 10:25:44 AM »
hi there,
i am replacing my current diy router with new electronics and motors. i have one question - my routers y-axis is driven by two stepper motors. i would like to purchase the following set http://cgi.ebay.at/CNC-Kit-4-Achs-Steuerkarte-263-Oz-in-Motor-Netzteil-/130515440262?pt=LH_DefaultDomain_77&hash=item1e63539286#ht_6311wt_1135 which includes a 4-axis controller. how do i connect/setup to get two motors for the y-axis? is this done in mach3 or is it done with the controller?
by the way, does anyone know if this set is good? my current setup includes a simple parallelboard, 4 easydriver stepper controllers and tiny nema17 motors. as the motors don“t have enough power i want to replace them with this kit as is has 4-times the power of my current setup.
i would be glad if someone could help me and wish all you out there a very nice day.
« Last Edit: May 18, 2011, 10:28:15 AM by mipu123 »
Offline kf2qd
  •  157 157
Re: y-axis driven by two motors
« Reply #1 on: May 18, 2011, 10:31:49 AM »
You could send the Y-Axis signals to 2 motors, or you could slave the A-Axis to the Y-Axis.
« Reply #2 on: May 18, 2011, 10:40:43 AM »
so does this mean this is setup in mach3?
« Reply #3 on: May 18, 2011, 10:52:12 AM »
Yes, you can slave them in Mach3
« Reply #4 on: May 18, 2011, 12:56:48 PM »
thank you - found it! have a nice day.
