Welcome, Guest. Please login or register.
Did you miss your activation email?
May 27, 2012, 09:57:52 PM
Login with username, password and session length
Search:     Advanced search
* Home Help Search Calendar Links Login Register
+  Machsupport Forum
|-+  Mach Discussion
| |-+  General Mach Discussion
| | |-+  Surfboard Shaping machine
Pages: « 1 2 3   Go Down
Print
Author Topic: Surfboard Shaping machine  (Read 792 times)
Beernuts
Active Member
Offline Offline
View Profile
« Reply #20 on: May 18, 2011, 08:01:38 AM »
Understand. Try the script Hood gave you and see how you go.
I would do this with just the Ref All Home button ( see standard 1024 screen). The script behind is:
DoButton( 24 )          -Reference z axis
DoButton( 23 )          -Reference Y axis
DoButton( 22 )          -Reference x axis
In the Homing/Limits Setup you can define where the switch position is located.  You would insert X=-18, Y=-326 and Z=-18.
You can additionally use individual home buttons for each axis as you will most likely only home Z in most cases. X and Y will usually not loose position.
Just an idea to keep things simple.
Logged
Pages: « 1 2 3   Go Up
Print
Jump to:
Powered by MySQL Powered by PHP Powered by SMF 1.1.16 | SMF © 2011, Simple Machines Valid XHTML 1.0! Valid CSS!
