Welcome, Guest. Please login or register.
Did you miss your activation email?
May 27, 2012, 09:53:48 PM
Login with username, password and session length
Search:     Advanced search
* Home Help Search Calendar Links Login Register
+  Machsupport Forum
|-+  Tangent Corner
| |-+  Bargain Basement
| | |-+  1 HP DC brush motor generator for spindle or wind mill
Pages: 1   Go Down
Print
Author Topic: 1 HP DC brush motor generator for spindle or wind mill  (Read 1051 times)
DennisCNC
Active Member
Offline Offline
View Profile
« on: May 14, 2011, 10:37:35 AM »
For sale is the pictured new motor.  This is very good quality permanent magnet DC motor that can be used in many applications.  The motor body in 1/4" steel has two large brushes as pictured.  Includes a 8' long 16-3 power cord that can be plugged in the wall outlet. Also has a ON/OFF switch and overload breaker.  Motor runs very smooth and quiet would make a great spindle motor with a variable speed control.
Price $55
Power 1 HP
Voltage 150 DC  or 120 AC with bridge rectifier( included)
Amperage 8.15 Amps Cont. or 1.14 Amps no load
Speed 3400 RPM
Rotation Reversible
Enclosure TEFC
Duty Continuous
Frame 42
Mount 4 10/32 tapped holes on face, 2-5/8" dia. B.C.
Shaft 5/16" dia. x 1-3/8" w/flat
Size 8-1/4" x 5" x 7"
Weight 19 lbs.
« Last Edit: May 14, 2011, 10:44:52 AM by DennisCNC » Logged
nunezelzorro
Holding
Offline Offline
View Profile
« Reply #1 on: August 12, 2011, 06:10:12 AM »
I want to by the motor my email is jnva@sbcglobal.net
Logged
Pages: 1   Go Up
Print
Jump to:
Powered by MySQL Powered by PHP Powered by SMF 1.1.16 | SMF © 2011, Simple Machines Valid XHTML 1.0! Valid CSS!
