May 27, 2012, 09:52:55 PM
Search:     Advanced search
+  Machsupport Forum
|-+  Third party software and hardware support forums.
| |-+  Newfangled Solutions Wizards (Moderator: Ron Ginger)
| | |-+  Adding multiple operations?
Pages: 1   Go Down
Print
Author Topic: Adding multiple operations?  (Read 458 times)
Taliesin
Active Member
Offline Offline
View Profile
« on: May 13, 2011, 05:28:18 AM »
Is it possible to add a few NFS operations together?
I have a batch of 30 parts that need machining.
I want to cut 3 x slots and I am using the Keyway wizard for each of the slots.
I do this individually and i have to change the wizard to do a new slot and keep the part in the vice.
Or I just do one slot on each part and change the part every time until i have done all the parts, then set up slot 2 and repeat.
How do I do all 3 operations in one hit?
Is it as simple as copying the 3 g codes generated by the wizards in one file?
I know many of you will frown at such a silly question but I really am a complete novice.
Please help!
Tal.
Taliesin
Active Member
Offline Offline
View Profile
« Reply #1 on: May 13, 2011, 05:58:32 AM »
Ack!.
That was a bit of a RTFM moment!
Read the F***ing Manual!
All sorted now, I was exiting the wizards when I could have selected another operation at the "operation selection" screen.
Pages: 1   Go Up
Print
Jump to:
