Hello Guest it is June 10, 2026, 11:11:26 AM
Author Topic: How to handle VFD with no Coils  (Read 6647 times)
« on: May 12, 2011, 02:35:59 PM »
New at brains.  I had Fwd and Rev working with the Standard Serial Modbus, but now I swap over to brains and Plugin Modbus.
My Teco 7300EV only uses holding registers instead of Coils.
I have a Brain working to Start and Stop the Spindle, and another to set the RPM and Overide.
It works in Forward only at the moment.
What I would like to do is find out the state of CW and CCW and send the proper value to the Holding Register as a 16 bit value instead of a coil / bit.
Would it work to use some user vars to set Run in one and Direction in the other then just AND them together in a formula, then ship out to the register?
Bit 0 - Stop = 0, Run = 1
Bit 1 - Forward = 0, Reverse = 1
So, sending a 1 would be Run in Forward, Sending a 3 Would be Run in Reverse, and sending a Zero Stops the spindle.
Is there a better way to do this.
Re: How to handle VFD with no Coils
« Reply #1 on: May 12, 2011, 04:03:18 PM »
I thought I could do something simple like:
CW Spindle On = Formula  f=1
CCW Spindle On = Formula f=3
It sure doesn't have the desired affects, especially since I can't turn off the spindle.
Right now, I'm back at having Spindle On - No Op  set to turn it on and off.
« Reply #2 on: November 06, 2011, 07:11:25 PM »
Can anyone help on this?
I have a register that can only be read with FC3 and written to with FC6.
That 16 bit registers uses bit flags.
Sending a 0 or 1 starts and stops the VFD.
How can I tell my brain to set bit 1?
Again,  If I knew how to do this I would be happy.
CW Write a 0
CCw Write a 3
Stop Write a Zero
Richard
