Hello Guest it is June 13, 2026, 02:29:39 AM
Author Topic: Outputs activated by hotkey?  (Read 7595 times)
« on: May 11, 2011, 08:42:14 AM »
Apologies if this is a dense question, but I'm new to Mach3!
I've got a PC/Relay board attached to my LPT port, which activates relays based on an output on pins 2-9 (turn on pin 9 & a coressponding relay is activated)
I've assigned Output#1 to port 1, pin 8, and toggling active low on/off activates the relay as I want it to.
Is there a way to attach this to a keyboard hotkey? So for example pressing F1 switches output 1 on/off?
Many thanks,
Dave.
  •  9,356 9,356
Re: Outputs activated by hotkey?
« Reply #1 on: May 11, 2011, 10:53:43 AM »
Hi Dave,
Yes it's pretty easy to do.
As an example if the spindle control is configured to output#1 the the F5 key will toggle your relay on and off.
Easy enough to change this, just experiment a bit and you will get the hang of it.
« Reply #2 on: May 11, 2011, 10:38:04 PM »
I think you are going to have to create a screen button to run the code to activate the ouput, then assign a hotkey to that button.
Just a thought, (;-) TP
