May 27, 2012, 09:42:32 PM
Search:     Advanced search
+  Machsupport Forum
|-+  Mach Discussion
| | |-+  problem setup mach3 under g540
Pages: 1   Go Down
Print
Author Topic: problem setup mach3 under g540  (Read 222 times)
komar1970
Active Member
Offline Offline
View Profile
« on: May 10, 2011, 09:05:32 AM »
I have a problem with cutting on my machine
I give an example driving machine
original distance from the project
Y AXIS 85.80mm dimension after cut 86.57mm
X AXIS 120MM dimension after cut 121.20mm
can you tell my wath problem i have
Tweakie.CNC
Active Member
Offline Offline
Super Kitty.
View Profile WWW
« Reply #1 on: May 10, 2011, 10:13:05 AM »
Have you checked that your steps per unit are correct. Al's calculator is here http://www.machsupport.com/forum/index.php/topic,16315.msg110286.html#msg110286
Success consists of going from failure to failure without loss of enthusiasm.  Winston Churchill.
Pages: 1   Go Up
Print
Jump to:
