May 27, 2012, 09:29:45 PM
Search:     Advanced search
+  Machsupport Forum
|-+  Mach Discussion
| | |-+  Mach offseting my work
Pages: « 1 2   Go Down
Print
Author Topic: Mach offseting my work  (Read 382 times)
BR549
Active Member
Offline Offline
View Profile
« Reply #10 on: May 07, 2011, 12:01:15 PM »
IF it were the fixture offsets then it still would cut correctly as the offset wouldbe active ALL the time.
I think what you are seeing is the the 0,0 is being set off the tool centerline BUT the cut is being "measured" off the tool radius.
Just a thought(;-) TP
Pages: « 1 2   Go Up
Print
Jump to:
