Hello Guest it is June 11, 2026, 07:52:48 AM
Author Topic: V carving using Mach 3  (Read 17392 times)
Re: V carving using Mach 3
« Reply #10 on: May 06, 2011, 07:33:49 PM »
What would you recommend for Accel settings?
« Reply #11 on: May 06, 2011, 07:44:07 PM »
Accel is a very machine dependent setting. I know guys with homebuilt rack and pinion machines typically use 30-50.
You want to set it as fast as your machine will allow, and still be reliable. Generally, the faster the accel, the better your CV performance.
« Reply #12 on: May 06, 2011, 07:49:53 PM »
I will give that a try.
thanks for the help!
