May 27, 2012, 09:24:37 PM
Search:     Advanced search
+  Machsupport Forum
|-+  Mach Discussion
| | |-+  4th Axis Rotary Table!!!
Pages: « 1 2   Go Down
Print
Author Topic: 4th Axis Rotary Table!!!  (Read 1078 times)
Jeff_Birt
Active Member
Offline Offline
View Profile WWW
« Reply #10 on: May 08, 2011, 10:34:52 AM »
They failed 100% of the time.
Wow! Well, I guess at least they were consistant Smiley
Happy machining , Jeff Birt
Hal
Active Member
Offline Offline
View Profile
« Reply #11 on: May 08, 2011, 01:52:06 PM »
I would go with the Sherline. There are many sites for tilt tables and right angle mounts.
If you need a larger indexer, look for a used HAAS unit. Maybe pricey, but industrial strength.
Jugster
Active Member
Offline Offline
View Profile
« Reply #12 on: May 09, 2011, 08:51:58 PM »
Jeff,
Thanks for the additional info.  I probable go ahead and order one from you in the next couple of weeks.  Just trying to do a clean up in my shop before I start another product.
Pages: « 1 2   Go Up
Print
Jump to:
