May 27, 2012, 09:19:36 PM
Search:     Advanced search
+  Machsupport Forum
|-+  Mach Discussion
| |-+  VB and the development of wizards
| | |-+  Micro drip system
Pages: 1   Go Down
Print
Author Topic: Micro drip system  (Read 289 times)
GMezzacapo
Active Member
Offline Offline
View Profile
« on: May 04, 2011, 12:43:13 PM »
Hi There, I have 2 questions
I am trying to find some way to use a peristaltic pump to add oil drops to my engrave, so I found a pump to do that but It can not run continuously, is there any way to the mach3 turn on 5 sec and off for 20sec a parallel port pin when the spindle is on?
When the gcode finish is there any way to the z axis will be more high than a 1mm? I always has to change manually the z en the gcode
Gianni
stirling
Global Moderator
Offline Offline
UK
View Profile WWW
« Reply #1 on: May 05, 2011, 04:51:41 AM »
Hi Gianni
see attached brain - it assumes your spindle is on OUTPUT1 and your pump is on OUTPUT2 - edit to suit.
your z will go wherever your gcode tells it to. If you're using CAM - change the settings there.
Ian
* Gianni pump.brn (1.71 KB - downloaded 37 times.)
GMezzacapo
Active Member
Offline Offline
View Profile
« Reply #2 on: May 05, 2011, 09:44:40 AM »
Ian, works great Thank you very much. You help me to discover a new part of the software.
Gianni
Pages: 1   Go Up
Print
Jump to:
