Hello Guest it is June 10, 2026, 09:05:08 PM
Author Topic: Newfangled solutions  (Read 33059 times)
Offline Rieks
  •  26 26
« on: April 26, 2011, 04:45:00 PM »
Hello,
I have a problem with the Newfangled solutions.
When starting the wizard "Circular hole pattern" drilling, the X Center DRO read's 1.000 mm
When I make X Center is 0 (zero) and Y Center is 0 (zero), save the settings an run
the program, all works well.
When I run the same program another time, the X Center moves to 1.00 mm.
This problem is very inconvenient for me.
Re: Newfangled solutions
« Reply #1 on: April 28, 2011, 09:52:53 PM »
The wizards should always remember their last value used. These values are stored in the file Newfangled.set.def in The Addons\Newfangled folder. Check to see that this file is not set to read-only. If you copied the wizard from a CD it might have been set read-only
Offline Rieks
  •  26 26
« Reply #2 on: April 29, 2011, 03:51:44 PM »
Hello Ron,
The file Newfangled.set.def is a archive file, bud, I discovered that the value You select for 'Material' appears in the Dro for X Center and the other way around.
I. most of the time  use Aluminium, i.c. Nr. 1.
If I select Brass, (5) the value for X Center will be 5
Something is wrong in this Wizard.
This Wizard is the only one I discovered, with this problem.
Rieks
« Reply #3 on: April 29, 2011, 06:06:50 PM »
That bug was fixed some time ago. Please get the latest version from this forum and insatll it.
Offline Rieks
  •  26 26
« Reply #4 on: April 30, 2011, 03:19:51 AM »
Hello Ron,
Where do I find the download link for the latest version?
I looked over this forum bud I didn't find the right search term.
Rieks
« Reply #5 on: April 30, 2011, 06:09:34 AM »
They are posted here in this forum topic. The latest is at http://www.machsupport.com/forum/index.php/topic,16550.0.html
I need to find ou thow to make a sticky topic and pin the latest version to the top of the forum
« Reply #6 on: April 30, 2011, 01:28:50 PM »
Ron,
I made a sticky topic for you to post the latest version to.
I tried to post the zip file with cap letters but it would not accept it.
« Last Edit: April 30, 2011, 01:35:03 PM by RICH »
Offline Rieks
  •  26 26
« Reply #7 on: April 30, 2011, 03:05:54 PM »
Ron,
I'm very sorry, bud the same curiosity still exists.
I downloaded the latest version two times to be sure, bud the value for material and X Center are somehow linked together.
The Material number is copied to the Dro for X Center.
When I make X Center 0 (zero) then The Material number turns to 0.
Somehow 1 in X Center is dominant, when I make no material choice, the number is 0 even then the value for
X Center is 1
Rieks
« Reply #8 on: April 30, 2011, 06:56:33 PM »
You are correct that the material DRO is the same as the X center. There was another duplicate that I had fixed. Im traveling now, I will correct this and release a new version when I get home next week. Sorry for the confusion and not checking your first report closer.
« Reply #9 on: May 24, 2011, 07:07:03 AM »
This has been fixed in V 2.86. See the sticky topic at teh top of this forum for the zip file
