Hello Guest it is June 09, 2026, 11:03:33 AM
Author Topic: Printed-circuit board milling  (Read 6817 times)
« on: April 25, 2011, 09:50:21 AM »
How it is possible to turn machine tool axes in axes XZ and YZ? On G68 turn it turns out to make only in axes XY. The Given function is necessary for definition of position of a surface of the printed-circuit board and turn of coordinates for a cut of an exact layer of a foil from a pcb. Or who else can than uses for definition of a surface and updating of coordinate Z ?
On the Chinese machine tools before start the pcb surface is checked by mill contact on a surface then updatings on curvature are brought and process of cutting of a foil begins.
Re: Printed-circuit board milling
« Reply #1 on: April 25, 2011, 03:56:12 PM »
Maybe someone else can provide more detailed help.
Quick read my Smid Book on G68 say's that you need to define desired plane G18 or G19 before the G68 command is used.
« Reply #2 on: April 25, 2011, 05:20:13 PM »
Mach will ONLY rotate XY (G17)with the G68 command.
« Reply #3 on: April 26, 2011, 12:29:15 PM »
thank you very much.
I will try will write a script which to realize the given function.
