Home
Downloads
Mach3
Plugins
CAM Post Processors
Screensets
Purchase
Support
Forum
Tutorial Videos
Documentation
Yahoo Group
Mach Wiki
Resources
Contact Us
Links
CNCZone
German Forum
Italian Forum
Korean Forum
Portugese (Brazil) Forum
Russian Forum (RSK CNCROUTER)
Thai Forum
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email?
May 27, 2012, 08:43:23 PM
1 Hour
1 Day
1 Week
1 Month
Forever
Search:
Advanced search
Select from and to languages
Chinese-simp to English
Chinese-trad to English
English to Chinese-simp
English to Chinese-trad
English to Dutch
English to French
English to German
English to Greek
English to Italian
English to Japanese
English to Korean
English to Portuguese
English to Russian
English to Spanish
Dutch to English
Dutch to French
French to English
French to German
French to Greek
French to Italian
French to Portuguese
French to Dutch
French to Spanish
German to English
German to French
Greek to English
Greek to French
Italian to English
Italian to French
Japanese to English
Korean to English
Portuguese to English
Portuguese to French
Russian to English
Spanish to English
Spanish to French
Mach Discussion
General Mach Discussion
circular interpolation not showing on arc cutting surface
Pages:
1
Go Down
« previous
next »
Author
Topic: circular interpolation not showing on arc cutting surface (Read 436 times)
bjhmc
Active Member
Offline
on:
April 25, 2011, 04:36:26 AM »
hello any body can help me to get a fine cutting surface for a milling operation of an arc/ circle shape.now the round surface are showing some steps after milling. Does the speed ,acceleration are playing the role regarding this matter or any thing else? does the circular interpolation is missing in mach3 ?
Last Edit: April 25, 2011, 04:51:52 AM by bjhmc
Tweakie.CNC
Active Member
Offline
Super Kitty.
Re: circular interpolation not showing on arc cutting surface
Reply #1 on:
April 25, 2011, 07:17:00 AM »
Not sure I fully understand but most CAD software draws circles as a number of straight lines, the lower the resolution the less the number of lines and worse the appearance. On the other hand, CAD/CAM that uses circular interpolation produces smooth contours without any of these visible straight lines.
Which CAD/CAM are you using to create your toolpaths and does it allow circular interpolation ?
Success consists of going from failure to failure without loss of enthusiasm. Winston Churchill.
bjhmc
Active Member
Offline
Reply #2 on:
April 26, 2011, 02:44:14 AM »
for this particular case i used an autocad dxf file and generated toolpaths using lazycam,can i change resolution in lazy cam?or any other cam software will give fine result?are u sure that the mach3 can do nothing regarding this?
Tweakie.CNC
Active Member
Offline
Super Kitty.
Reply #3 on:
April 26, 2011, 03:23:13 AM »
As far as I am aware Mach will only produce the GCode it is given.
Autocad or other CAD/CAM is the place to improve your resolution as LazyCam has extremely limited capabilities.
If you draw your work and export as, for example, .jpg format then using other programs such as Vector Magic which are capable of generating extremely high quality .dxf files may be an option but there are many many alternatives to this and everyone has their own preferences.
bjhmc
Active Member
Offline
Reply #4 on:
April 28, 2011, 05:14:27 AM »
any way i forgot to say thanks for your reply, so thanks for the replies.
let me to bring this matter to a small area. may i know that a simple G-code for a circle /Arc using g2 or g3 with a medium feed rate will give a fine cutting surface.consider that all the other supporting g-codes are also included. at this condition what may be the reason for a "stepped surface" after the arc/circle milling?
bjhmc
Active Member
Offline
Reply #5 on:
April 28, 2011, 05:43:28 AM »
Dear Mr.Tweakie , can u give that spindle motor's(black colour)full specifications shown on your website in a CNC machine? from where shall i get that?
Tweakie.CNC
Active Member
Offline
Super Kitty.
Reply #6 on:
April 28, 2011, 05:56:36 AM »
Sorry but I have never seen another one of these.
(It is 240 volt 3 phase, has internal shaft brushes to connect rotor to frame (perhaps ceramic bearings) used to have a magnetic shaft brake on the top where I have now fitted a cooling fan and had a high ratio planetary gearbox on the front. It is German made and came from a large format printer transport mechanism - it was perhaps used as a servo motor ?).
ger21
Global Moderator
Offline
Reply #7 on:
April 28, 2011, 04:51:45 PM »
I'd say exactly the opposite. Most CAD software draws circles as circles or arcs, and NOT straight lines. Autocad definitely does.
As for your stepped circles, lots of things could cause that. How is your machine driven?
http://home.comcast.net/~cncwoodworker/2010.html
TramAlot
Active Member
Offline
Reply #8 on:
April 28, 2011, 09:00:25 PM »
most of the cad programs make circles with as little as 14 segments per quadrent or maybe even per diameter as default. usually a right click on the entity and hit properties and in a "surface" or "solid" tab you can change this to as much as 90. 45 gives me good circles and less code, but only bigger then an inch,
BR549
Active Member
Online
Reply #9 on:
April 28, 2011, 09:16:58 PM »
I am with Gerry Most cads make circles as arcs. I have used most major players in the cad arena. Only the converted art drawing program seems to do the line method.
Pages:
1
Go Up
« previous
next »
Jump to:
Please select a destination:
Mach Discussion
=> General Mach Discussion
=> Mach3 under Vista
=> Quantum
=> Brains Development
=> Video P*r*o*b*i*n*g
=> Mach Screens
===> Works in progress
===> Finished Screens
===> Flash Screens
===> JetCam screen designer
===> CVI MachStdMill (MSM)
=> Feature Requests
=> Non English Forums
===> Italian
===> French
===> Spanish
===> Chinese
===> German
===> Russian
===> Romanian
===> Japanese
===> Vietnamese
=> FAQs
*****VIDEOS*****
=> *****VIDEOS*****
General CNC Chat
=> Share Your GCode
G-Code, CAD, and CAM
=> LazyCam (Beta)
=> LazyTurn
=> Tempest Trajectory Planner
=> Contec
=> dspMC/IP Motion Controller
=> HiCON Motion Controller
=> Galil
=> Newfangled Solutions Wizards
=> Mach3 and G-Rex
=> Mesa
=> Modbus
=> NC Pod
=> PoKeys
=> SmoothStepper USB
=> Sieg Machines
Tangent Corner
=> Tangent Corner
=> Competitions
=> Polls
=> Bargain Basement
Support
=> Downloads
===> XML files
===> Post Processors
===> Macros
===> Tutorials
===> Others
===> Beta Brains
===> Screen Sets
===> Documents
===> MACH TOOL BOX
=> One on one phone support.
Mach4
=> Mach4 pre-Alpha Testing
Loading...
