Hello Guest it is June 12, 2026, 03:27:15 AM
Author Topic: burned out stepper motor? Symptoms.  (Read 26239 times)
Re: burned out stepper motor? Symptoms.
« Reply #10 on: April 24, 2011, 02:55:33 PM »
I have a 6 axis mill, all the axis are already taken up from the C23 board;)
Then you can build an amplifier circuit that would provide the same output current to both drives.
Offline BarryB
  •  267 267
« Reply #11 on: April 24, 2011, 03:38:55 PM »
I'm just noticing this now.  The mill did sit for about 4 months but didn't do this before.  (I know, rediculous letting your mill sit that long).  I've just made a new control box.   Since the old mill wiring didn't reach the new box location, rewired the mill too, so I'm back to basically first time operation again.  Fun stuff, not.
« Reply #12 on: April 24, 2011, 05:17:53 PM »
You should be running a slaved axis.  Let Mach send step and dirextion signals to the A axis on the BOB and connect your A axis drive to the A axis on the BOB.  You already have the parts to do it.  You just need to rewire a little and set up the A axis in Mach.
What he's done should work just fine.  AFAIK, the only thing he's lost by NOT setting it up in Mach as a slaved axis is the ability to "zero" the slaved axis through the GUI.
