Hello Guest it is June 12, 2026, 03:28:40 AM
Author Topic: burned out stepper motor? Symptoms.  (Read 26246 times)
Offline BarryB
  •  267 267
« on: April 23, 2011, 11:13:20 PM »
Hello, I have a stepper motor that seems to not run occasionally.  Other times it works fine. Of course this motor is on a twin X axis, meaning that the x-axis has two stepper motors each with the same signal.  When one fails, this moves only 1/2 of the machine, which is very very bad!  Basically worst possible one to go out.
Is this a normal symptom that you guys have seen?  I'm wondering if I need to order a new motor, or I need to investigate something else.  When they go out, do they act flakey and then finally give up the ghost, or do they just go out immediately!
This is a NEMA 34, 1290 oz motor.  It's moving a gantry that weighs probably 250 lbs.
Barry
Re: burned out stepper motor? Symptoms.
« Reply #1 on: April 23, 2011, 11:17:22 PM »
It is FAR more likely to be the controller, or wiring than the motor.
Offline BarryB
  •  267 267
« Reply #2 on: April 23, 2011, 11:27:49 PM »
The controller is the same for both X axis stepper motors, so if it works on one, it should work on both.  I'll check the wiring.  I hope it isn't mechanical.  That's the part that scares me, and the mill is big and heavy.
« Reply #3 on: April 23, 2011, 11:47:08 PM »
If you're really running two motors in parallel on a single controller, that could well be your problem.  That will not work reliably.
Offline BarryB
  •  267 267
« Reply #4 on: April 24, 2011, 02:05:23 PM »
why wouldn't that work reliably Ray?  The signal (from a C23 board) is split and both motor drivers (gecko 203v's) receive that signal.  Or were you thinking I was using one motor driver for two motors?
« Reply #5 on: April 24, 2011, 02:22:33 PM »
"The controller is the same for both X axis stepper motors, so if it works on one, it should work on both." - So now you're saying it's NOT the same controller for both.  Each motor has it's own G203V, right?  So swap the motor wires between the two G203Vs.  If the problem moves to the other motor, then you have a G203V that is either hosed, or improperly setup.  If not, then swap the motors themselves.  If the problem follows the motor, then you have your answer.  If not, then the problem is mechanical.  Steppers will almost always either work correctly, or not at all.
My money would be on a mechanical problem....
Offline BarryB
  •  267 267
« Reply #6 on: April 24, 2011, 02:26:24 PM »
Yes, I think we got crossed on the terminology.  I'll try and narrow this down.  I did notice that a coupler was busted when tearing this down, so it could be that, or that could be causes by the motor not turning.  Oh the joy;)
« Reply #7 on: April 24, 2011, 02:28:58 PM »
When you connect two drives to one output, you pull twice the current from that output.  If the current on one of the lines going to the drive drops below what the drive needs, the drive will act as if it is missing steps, or worse case, not work at all.  It's not reliable because sometimes it works and sometimes it doesn't.
You should be running a slaved axis.  Let Mach send step and dirextion signals to the A axis on the BOB and connect your A axis drive to the A axis on the BOB.  You already have the parts to do it.  You just need to rewire a little and set up the A axis in Mach.
Offline BarryB
  •  267 267
« Reply #8 on: April 24, 2011, 02:33:03 PM »
I have a 6 axis mill, all the axis are already taken up from the C23 board;)
« Reply #9 on: April 24, 2011, 02:40:59 PM »
swap driver boards and see if it moves to the other motor.
And how long have you run it it before this started?
