May 27, 2012, 08:28:17 PM
Search:     Advanced search
+  Machsupport Forum
|-+  Mach Discussion
| | |-+  Axis calibration
Pages: 1   Go Down
Print
Author Topic: Axis calibration  (Read 271 times)
mickelsen
Active Member
Offline Offline
View Profile
« on: April 21, 2011, 11:33:48 PM »
I've seen mention of an axis calibration function.  I've looked through all of the pull-down menus but I can't find it.  Could someone tell me where it is located?
Mark
ostie01
Active Member
Offline Offline
View Profile
« Reply #1 on: April 22, 2011, 12:09:10 AM »
This function is not in the menu option.
Look at page SETTINGS (Alt-6)
Bottom left , you will see Axis Calibration, just above the Reset Button.
Jeff
larryc
Active Member
Offline Offline
View Profile
« Reply #2 on: April 22, 2011, 07:48:50 AM »
I also thank you I was just going to ask the same question. But thought I would check first. and I found this one.
 It has been a long time for me sence I last did a set up on my machine . Couldnt find the set up option.
 Thanks again from larry in canada as well.
Pages: 1   Go Up
Print
Jump to:
