Home
Downloads
Mach3
Plugins
CAM Post Processors
Screensets
Purchase
Support
Forum
Tutorial Videos
Documentation
Yahoo Group
Mach Wiki
Resources
Contact Us
Links
CNCZone
German Forum
Italian Forum
Korean Forum
Portugese (Brazil) Forum
Russian Forum (RSK CNCROUTER)
Thai Forum
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email?
May 27, 2012, 08:27:18 PM
1 Hour
1 Day
1 Week
1 Month
Forever
Search:
Advanced search
Select from and to languages
Chinese-simp to English
Chinese-trad to English
English to Chinese-simp
English to Chinese-trad
English to Dutch
English to French
English to German
English to Greek
English to Italian
English to Japanese
English to Korean
English to Portuguese
English to Russian
English to Spanish
Dutch to English
Dutch to French
French to English
French to German
French to Greek
French to Italian
French to Portuguese
French to Dutch
French to Spanish
German to English
German to French
Greek to English
Greek to French
Italian to English
Italian to French
Japanese to English
Korean to English
Portuguese to English
Portuguese to French
Russian to English
Spanish to English
Spanish to French
Mach Discussion
General Mach Discussion
PWM VS Pins 2-9
Pages:
1
Go Down
« previous
next »
Author
Topic: PWM VS Pins 2-9 (Read 358 times)
Zero Cool
Active Member
Offline
PWM VS Pins 2-9
on:
April 20, 2011, 09:26:07 PM »
Why is it that i can only get Mach to output a PWM signal on pins 2 through 9???
Pins 1, 14,16 &17 are output pins as well but no matter what i do i cannot get a PWM signal on these pins. but pins 2-9 work just fine???
I see that Mach has a setting to use port2 pins 2-9 as inputs instead of outputs. I was hoping to use that functionality but i can if i cant get a PWM signal to work on pins 1, 14,16 or 17
ger21
Global Moderator
Online
Re: PWM VS Pins 2-9
Reply #1 on:
April 20, 2011, 09:36:58 PM »
I use PWM to control a Super PID speed control and use either pin 14 or 16, but don't know which right now.
What are you trying to do?
http://home.comcast.net/~cncwoodworker/2010.html
Zero Cool
Active Member
Offline
Re: PWM VS Pins 2-9
Reply #2 on:
April 20, 2011, 09:41:25 PM »
I need to output the pwm signal to my custom built motor controller.
I looked at the SuperPID units and the units i saw are not PWM....Pulse Width Modulated. they are a traic based controller. how are you interfacing the PWM signal to the SuperPID??
ger21
Global Moderator
Online
Re: PWM VS Pins 2-9
Reply #3 on:
April 20, 2011, 09:49:51 PM »
I built a simple circuit to convert the PWM to 0-5V. It's on page 22 of the manual, and only cost a few $.
http://www.vhipe.com/product-private/SuperPID-v1_Instructions.pdf
Zero Cool
Active Member
Offline
Re: PWM VS Pins 2-9
Reply #4 on:
April 20, 2011, 09:54:40 PM »
I built a custom motor controller that takes the PWM signal, opto isolates it and feeds it to a IC Mosfet driver and then to a power Mosfet to control the spindle motor directly. works great! But i want to use Pins 1, 14,16 or 17 to output the PWM signal.
I have a dual Parallel port card in my PC. and i tried both ports and same deal.
Zero Cool
Active Member
Offline
Re: PWM VS Pins 2-9
Reply #5 on:
April 27, 2011, 05:54:09 AM »
I am having other problems now. I moved things around to get a PWM output from pin 6 and its not working. I have figured out that if i press the rest button the PWM will start. but only at the minimum speed. If i press the speed up/down buttons it just shuts off.
I want to use 400hz as my PWM base frequency. I have a direct drive spindle. I have the pulley ratio set for 5000min and 30000max with a ratio of 1
Pages:
1
Go Up
« previous
next »
Jump to:
Please select a destination:
Mach Discussion
=> General Mach Discussion
=> Mach3 under Vista
=> Quantum
=> Brains Development
=> Video P*r*o*b*i*n*g
=> Mach Screens
===> Works in progress
===> Finished Screens
===> Flash Screens
===> JetCam screen designer
===> CVI MachStdMill (MSM)
=> Feature Requests
=> Non English Forums
===> Italian
===> French
===> Spanish
===> Chinese
===> German
===> Russian
===> Romanian
===> Japanese
===> Vietnamese
=> FAQs
*****VIDEOS*****
=> *****VIDEOS*****
General CNC Chat
=> Share Your GCode
G-Code, CAD, and CAM
=> LazyCam (Beta)
=> LazyTurn
=> Tempest Trajectory Planner
=> Contec
=> dspMC/IP Motion Controller
=> HiCON Motion Controller
=> Galil
=> Newfangled Solutions Wizards
=> Mach3 and G-Rex
=> Mesa
=> Modbus
=> NC Pod
=> PoKeys
=> SmoothStepper USB
=> Sieg Machines
Tangent Corner
=> Tangent Corner
=> Competitions
=> Polls
=> Bargain Basement
Support
=> Downloads
===> XML files
===> Post Processors
===> Macros
===> Tutorials
===> Others
===> Beta Brains
===> Screen Sets
===> Documents
===> MACH TOOL BOX
=> One on one phone support.
Mach4
=> Mach4 pre-Alpha Testing
Loading...
