Hello Guest it is June 10, 2026, 03:22:31 AM
Author Topic: motors not turning  (Read 7797 times)
motors not turning
« on: April 14, 2011, 03:10:08 PM »
NEW ON CNC - can  the stepper motors move when you install MACH3 DEMO?
I'm using C35 breakout board,a digital stepping driver and motors KL23H286-20-8b from KELINGINC ELECTRONIC  and I can't make the motor to turn,Help!!
Re: motors not turning
« Reply #1 on: April 14, 2011, 03:38:37 PM »
Does your controller need a specific XML file? My Gecko requires one for it to work.
« Reply #2 on: April 14, 2011, 03:48:37 PM »
Thanks,let me look into?
  •  9,356 9,356
« Reply #3 on: April 15, 2011, 01:28:52 AM »
Hi Raul,
Welcome to the forum.
The Mach3 demo version will work just fine.
Your C35 requires an enable signal to get any output - check that the EN terminal is connected to +5Volts.
Hope this helps.
