Hello Guest it is June 09, 2026, 04:06:19 PM
Author Topic: Question regarding GetParam( String ) and SetParam( String )  (Read 27534 times)
« on: April 13, 2011, 12:44:35 PM »
Could one of you fine folks help me retrieve a parameter from Mach, and store it in a text box on the Flash screen?
Hope that makes sense?
Thanks guys,
Chris
Offline zealous
  •  489 489
  • HI!
    • Artsoft Solutions
Re: Question regarding GetParam( String ) and SetParam( String )
« Reply #1 on: April 25, 2011, 09:36:52 PM »
Sorry for the delay, I did not see the post.
you can call a VB command to either set a Userlabel,LED,DRO OR write to a text file which Flash then could load.
I.E.
Code: [Select]
loadSettings =
'value = GetParam("Boundry")'+"\r"+
'if  value = 1 then'+"\r"+
'SetUserLED(1816,1)'+"\r"+
'else'+"\r"+
'SetUserLED(1816,0)'+"\r"+
'end if'
fscommand("VBMacro", loadSettings);
Let me know if you want to read a file in Flash will give an example.
« Reply #2 on: April 26, 2011, 12:46:55 AM »
Hey cool zealous, I think that's what I was after. May take me a bit to try it out...way too many projects right now  ;). I'll keep you posted.
Thanks again,
Chris
