Hello Guest it is June 09, 2026, 07:14:01 PM
Author Topic: One handed wireless Mach3 Controller  (Read 8869 times)
« on: April 12, 2011, 07:05:52 PM »
Not sure if this is the right place to post this but Thought I would share this...............
I have used a few different controllers for my PS3.
I have a couple in a box I no longer use.
I took the Fragnstein out this morning and decided to set it up for Mach3.
It is wireless and fully configurable. I programmed it on my main PC and then
down loaded it to the unit. The settings can be saved as well.
Then you just plug it in the PC running Mach3 and your good to go.
Both the mouse and the nunchuck have an auto sleep mode, which I find nice
because once it is setup and running G code you don't need manual action
and you won't accidently bump a key.
http://home.cogeco.ca/~fileme/vids/Fragnstein.wmv
  •  9,356 9,356
Re: One handed wireless Mach3 Controller
« Reply #1 on: April 13, 2011, 01:38:14 AM »
Thank you for posting the information.
