Hello Guest it is June 10, 2026, 08:19:46 PM
Author Topic: 19 hrs and 4 minutes. DARN IT! - New Personal Record  (Read 10305 times)
« on: April 09, 2011, 05:39:59 PM »
I set a new personal record with 358,598 lines of code and a continuous run without a failure.  TWICE (two halves of a mold).
However we have to work on the simulation.  It was off.  I setup Mach on my design computer with the same motor tuning as on the computer I run the Taig with and it was off.  I ran a simulation on a piece of G-code with over 358K lines of code.  The simulation said it should take 18 hrs and 57 minutes.  I set the alarm on my phone and let it run while I had dinner, slept, had breakfast chased down a battery for my bike, worked on another design, had lunch, etc etc...  I was there just before it was supposed to finish, and I had to stand there twiddling my thumbs for 7 hole minutes.  Bogus man!  Bogus.
LOL.
Actually, I think that was pretty darn good calculating considering that it took a couple hours for the simulation to run.
« Last Edit: April 09, 2011, 05:43:20 PM by Bob La Londe »
Re: 19 hrs and 4 minutes. DARN IT! - New Personal Record
« Reply #1 on: April 09, 2011, 05:45:35 PM »
Completely unforgivable. Those are 7 minutes of your life you will NEVER get back, Bob.
  •  9,356 9,356
« Reply #2 on: April 10, 2011, 04:09:48 AM »
19 hours - that's some feat.  I wonder what the actual record is ?
(My personal best was just 342,000 lines in around 8 hours).
Offline kvom
  •  37 37
« Reply #3 on: April 20, 2011, 03:00:47 PM »
The simulation run is less than 50 lines/sec;  I think there is room for improvement in the simulation speed.  Still it was accurate to .6% which is darn good.
« Reply #4 on: July 16, 2011, 02:12:39 PM »
Well, I have done a bunch of cuts since then that were in this time frame, but I just set a new personal records.  Over a million lines of code.
I would actually have to add up the lines from seven GCODE files to see how many lines it takes to cut this part, but the finish pass file only with a high resolution is 1,118,540 lines.
P.S.  I seem to recall complaining a while back about running over a day and the hour meter not showing it right, but that seems to have changed in the latest version I have installed.  It now shows a day counter digit.  This finish pass takes 27 hours to run.  Thanks guys.
  •  9,356 9,356
« Reply #5 on: July 17, 2011, 12:41:44 AM »
Come on Bob you have to show us some pictures of the finished work  ;D
