Hello Guest it is June 09, 2026, 07:10:24 PM
Author Topic: Which probe is better.....?  (Read 10048 times)
Offline jevs
  •  315 315
« on: April 08, 2011, 12:33:35 AM »
I am looking for a probe to do digitizing and also edge and center finding etc. Which of these is better or more accurate?
http://www.wildhorse-innovations.com/index.php?_a=viewProd&productId=80
http://www.imsrv.com/deskcnc/probe.htm
Or should I be looking for something better? If so what would it be?
Re: Which probe is better.....?
« Reply #1 on: April 08, 2011, 01:57:29 AM »
Check out Zarzuls probe, you will find the thread in the bargain basement section of the forum.
http://www.machsupport.com/forum/index.php/topic,5004.0.html
Offline jevs
  •  315 315
« Reply #2 on: April 08, 2011, 07:46:23 AM »
I beleive his probe is the first one I linked to at Wildhorse? I read all those posts, but I still don't know which of the two is better. One is nearly 3 times as expensive, but is it better (more accurate or better repeatability)?
Also are these probes even any good for edge finding, or are they not accurate enough?
« Reply #3 on: April 08, 2011, 08:32:40 AM »
I made my own probe and its very accurate, it is along the same lines as the ones you linked to, ie the 3 rod and ball type. I dont use it for probing and it was never my intention to use it for that, it was made for edge finding and is extremely repeatable, I have it true to less than 0.005mm and it will repeat at less than I can measure. So from that I would say there is no reason to think either of the two above would be any different.
« Reply #4 on: April 08, 2011, 02:53:16 PM »
I have used the IMSRV model for over 5 years without fail and it is VERY accurate.
Offline jevs
  •  315 315
« Reply #5 on: April 08, 2011, 09:10:46 PM »
I ordered 2 of the wildhorse ones. I am going to dedicate one to tool setting and one to probing. I figure these are worth a shot since I can get two for less than one of the others that may not be any better....
