Hello Guest it is June 09, 2026, 03:26:45 PM
Author Topic: Need a Tool path to level our Table  (Read 16498 times)
Offline cdis
  •  11 11
« on: April 06, 2011, 02:43:19 PM »
We are new users to CNC and need a tool path to level our router>  We have a sub facia that we screw down our substrate to.  Hope you can help?
Thanks Neil
Re: Need a Tool path to level our Table
« Reply #1 on: April 06, 2011, 02:53:38 PM »
Hi Neil,
  Take a look at the Surfacing wizards.
I've used the "Down in X" one before and it worked really well.
Russ
Welcome to the forum !
Offline cdis
  •  11 11
« Reply #2 on: April 06, 2011, 05:35:04 PM »
Thank you for your reply.  IS this in Mach 3?
Neil
« Reply #3 on: April 06, 2011, 05:36:18 PM »
Yes, click the wizard button and you will get a list of the available ones.
« Reply #4 on: April 06, 2011, 07:14:36 PM »
... or you can hit this button.
The first one called "Surface" is missing the bitmaps on my installation so I never tried it but I have now used both of the other 2 and they do OK.
Russ
Offline cdis
  •  11 11
« Reply #5 on: April 06, 2011, 08:18:19 PM »
Thanks for the Info.  DO any of you know anybody that could give me over the phone help?  I would be willing to pay.  It has been a year sunce I have used this software and need a little  help in Settin up my Hom on the system and some other Items.
Thanks Again for your help
Offline cdis
  •  11 11
« Reply #6 on: April 06, 2011, 09:33:21 PM »
Thanks again for the info on the wizzards.  How can I change the parameters?  My surface is 48"x 96" and I am using a 1 1/4"Spoilboard Cutter from Onsrud and will be citting a depth of .250.  Thanks again
« Reply #7 on: April 07, 2011, 01:10:54 AM »
Click on the DROs and then type in the values you want then press the enter key on your keyboard.
« Reply #8 on: April 07, 2011, 05:59:30 AM »
Hi Neil,
  Here is an example of "Down in X" for a table your size. "Down in Y" would be similar.
Just click on the parameter that you want to change and it will be highlighted. Enter the value you want , then hit ENTER (like Hood said).
Unlike other wizards, the FINISH cut is ADDED to the TOTAL depth so you have to leave it at ZERO or you will get 2 passes ... unless that is what you want.
Use you own settings and feed rate, this is just an example.
Russ
« Last Edit: April 07, 2011, 06:04:59 AM by Overloaded »
Offline cdis
  •  11 11
« Reply #9 on: April 07, 2011, 06:21:13 PM »
Thanks for the great info.  When I got to the page and click on the field I want to change it does highlight but iam not able to type anything in the field.  Have any sujestions?
