Hello Guest it is June 10, 2026, 12:15:12 PM
Author Topic: Configuration change problem  (Read 10720 times)
« on: March 30, 2011, 02:33:57 PM »
I used multipass and nesting wizards couple weeks ago with great success.
This week I tried them again with another part and the results are baffling to me.  Rather than following the geometry for each pass, it makes several irrelevant (to me) lines.  I thought it was in the part CAD, so I made up just a simple rectangle with fillets at the coners and it does the same thing.  Without multipass it is fine.
I figured that I must have changed the configuration file to cause this.  So, I reinstalled Mach3 with no better affect.
If someone could take a look, I would appreciate it.
With the nesting wizard, the repeated parts are offset in X and Z, even though X is zero in the screen.  I'm not sure what the X offset value comes from, since it isn't the same as Y that I entered.  I'm hoping what is wrong for multipass is same for nesting.
Steve.
Re: Configuration change problem
« Reply #1 on: March 30, 2011, 06:09:23 PM »
Can you attach the original file before you ran the wizard.
« Reply #2 on: March 30, 2011, 06:12:03 PM »
Hood,
Justplate.txt is the original and justplatemp.tap is after multipass.
Steve.
« Reply #3 on: March 30, 2011, 06:13:06 PM »
::) its late here ;D
« Reply #4 on: March 30, 2011, 06:30:59 PM »
Sorry will have to come back to this if no one else has answered. I am crap at code anyway but brains working even less than normal because its late here ;D
Think it could have something to do with the G53 or possibly the tool height offset but I never use the wizard so not sure what to expect.
« Reply #5 on: March 31, 2011, 04:19:02 AM »
You have a line that has G01Z0.5 F10. if you change that to G01Z-0.5 F10. see if it now does what you expect when you run it throuh the multipass wizard.
