May 27, 2012, 07:15:43 PM
Search:     Advanced search
+  Machsupport Forum
|-+  Mach Discussion
| | |-+  Add DRO for rapid feed rate override
Pages: 1   Go Down
Print
Author Topic: Add DRO for rapid feed rate override  (Read 262 times)
ostie01
Active Member
Offline Offline
View Profile
« on: March 30, 2011, 02:09:23 PM »
Would like to add a DRO for Rapid feed rate override.
On my pendant, I have a 3 positions rotary switch that I would like to use to set rapid feed rate to 25%, 50% and 100%
I use 3 inputs on the ModIO, no analog input available.
If for example, the switch is on position 25%, would like to write that value to that DRO, and so on for 50% and 100%.
I have tried to write a brain but stuck with it.
Is someone have any idea on how can I do that or any clue would be really appreciated.
I already set up a Spindle speed override, feed override and the third analog input is for the MPG selection mode.
Jeff
Active Member
Offline Offline
Carnoustie, Scotland
View Profile
« Reply #1 on: March 30, 2011, 05:17:25 PM »
Any idea what the input format is in a Brain for the ModIO? Afraid I dont as I have never used one but the rest is easy enough.
ostie01
Active Member
Offline Offline
View Profile
« Reply #2 on: March 30, 2011, 10:49:31 PM »
That is the ''easy part enough'' that I have problem with.
I don't know how to do it with brain.
Jeff
Active Member
Offline Offline
View Profile
« Reply #3 on: March 31, 2011, 02:29:51 AM »
Do you know what form the ModIO inputs are in a Brain. I know what the Brain needs in the Modbus ranges for my PLC but the ModIO will likely be totally different.
Pages: 1   Go Up
Print
Jump to:
