May 27, 2012, 07:15:15 PM
Search:     Advanced search
+  Machsupport Forum
|-+  Mach Discussion
| | |-+  Is there a Code to put into a program to have mach probe
Pages: 1   Go Down
Print
Author Topic: Is there a Code to put into a program to have mach probe  (Read 305 times)
fixittt
Active Member
Offline Offline
View Profile
« on: March 30, 2011, 08:20:58 AM »
Is there a Code lto put into a program to have mach probe?
I want to be able to add a line of code in my program to have mach probe the tool and then start running the program.
Any such animal?
ger21
Global Moderator
Offline Offline
View Profile WWW
« Reply #1 on: March 30, 2011, 10:46:41 AM »
Yes, just write an M code probing macro, and call the M code. You'd just need to modify one of the many auto zero macros that are floating around.
G31 is what you'd use to probe.
fixittt
Active Member
Offline Offline
View Profile
« Reply #2 on: March 30, 2011, 12:10:19 PM »
i appreciate the reply,
can you elaborate on how to write the macro?  I have never done it before....... just pretend like Im an idiot..... better yet, dont pretend LOLOL
ostie01
Active Member
Offline Offline
View Profile
« Reply #3 on: March 30, 2011, 01:58:57 PM »
Some example of probing routine that you can use and update with your own parameters.
Open the VB editor and paste the code.
Jeff
* Another Probe Routine.doc (21.5 KB - downloaded 50 times.)
* Another tool probe macro.doc (20 KB - downloaded 35 times.)
AndrewM
Support Tech
Administrator
Offline Offline
View Profile
« Reply #4 on: March 30, 2011, 02:22:56 PM »
Its all done in visual basic, you will need to learn this to do any kind of editing or writing.
Pages: 1   Go Up
Print
Jump to:
