Hello Guest it is June 09, 2026, 10:30:19 AM
Author Topic: Is there a Code to put into a program to have mach probe  (Read 9395 times)
« on: March 30, 2011, 08:20:58 AM »
Is there a Code lto put into a program to have mach probe?
I want to be able to add a line of code in my program to have mach probe the tool and then start running the program.
Any such animal?
Re: Is there a Code to put into a program to have mach probe
« Reply #1 on: March 30, 2011, 10:46:41 AM »
Yes, just write an M code probing macro, and call the M code. You'd just need to modify one of the many auto zero macros that are floating around.
G31 is what you'd use to probe.
« Reply #2 on: March 30, 2011, 12:10:19 PM »
i appreciate the reply,
can you elaborate on how to write the macro?  I have never done it before....... just pretend like Im an idiot..... better yet, dont pretend LOLOL
« Reply #3 on: March 30, 2011, 01:58:57 PM »
Some example of probing routine that you can use and update with your own parameters.
Open the VB editor and paste the code.
Jeff
andrewm
« Reply #4 on: March 30, 2011, 02:22:56 PM »
Its all done in visual basic, you will need to learn this to do any kind of editing or writing.
