Hello Guest it is June 09, 2026, 10:47:24 AM
Author Topic: need help with calculating the mechanical drive  (Read 9073 times)
« on: March 27, 2011, 04:49:21 PM »
I am working on my rebuilt cnc mill, how can i calculate the setting for motor tuning.
the stepper motor has a gear 18:30 I don't know the thread of the spindle on the X axis.
We did some test runs and came on a figure of 1375 for 75mm I can't explane this outcome I missing 0.10mm with this out come
Is there anyone how can help me to get things done????
Gr. Jord  ??? ??? ???
Re: need help with calculating the mechanical drive
« Reply #1 on: March 27, 2011, 04:53:19 PM »
You could use the SetSteps per Unit button on the settings page (just above the reset button). Personally I prefer calculating the numbers but as long as your measurements are accurate when using the Set Steps per Unit button then you should be close.
« Reply #2 on: March 27, 2011, 04:56:21 PM »
one moment i am looking for it.
thank for your quick response
gr. jord
« Reply #3 on: March 27, 2011, 05:17:13 PM »
gr. jord
« Reply #4 on: March 27, 2011, 05:21:28 PM »
See the scrrenshot below for the buttons location.
« Reply #5 on: March 27, 2011, 06:10:10 PM »
thanks this will work I think, I will let you know if it's ready.
Going to bed it's 01:20 in the morning.
see you soon.
jord
