Home
Downloads
Mach3
Plugins
CAM Post Processors
Screensets
Purchase
Support
Forum
Tutorial Videos
Documentation
Yahoo Group
Mach Wiki
Resources
Contact Us
Links
CNCZone
German Forum
Italian Forum
Korean Forum
Portugese (Brazil) Forum
Russian Forum (RSK CNCROUTER)
Thai Forum
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email?
May 27, 2012, 07:00:11 PM
1 Hour
1 Day
1 Week
1 Month
Forever
Search:
Advanced search
Select from and to languages
Chinese-simp to English
Chinese-trad to English
English to Chinese-simp
English to Chinese-trad
English to Dutch
English to French
English to German
English to Greek
English to Italian
English to Japanese
English to Korean
English to Portuguese
English to Russian
English to Spanish
Dutch to English
Dutch to French
French to English
French to German
French to Greek
French to Italian
French to Portuguese
French to Dutch
French to Spanish
German to English
German to French
Greek to English
Greek to French
Italian to English
Italian to French
Japanese to English
Korean to English
Portuguese to English
Portuguese to French
Russian to English
Spanish to English
Spanish to French
General CNC Chat
Show"N"Tell ( Your Machines)
CNC Record Cutting Lathe
Pages:
1
Go Down
« previous
next »
Author
Topic: CNC Record Cutting Lathe (Read 976 times)
JungleStreetRecords
Active Member
Offline
on:
March 27, 2011, 02:02:18 AM »
Alrighty, I started making my own machine about a month ago and wanted to make a record cutter so I could cut my own tunes here at home. The only problem was that some manufacturers charge about 10 grand for a decent cutter. Forget that, I'll build my very first machine ever myself, program it and get it running the way I'd like.
Though a work in progress, it all starts with an idea that you build on top of, and I did just that. I'm building my CNC record cutting lathe right on top of a Gemini SA 600 DJ turntable!
To my knowledge, there aren't any CNC record cutting machines out there, and people keep telling me if I want a record cutter, I'd be better off to build one. With my setup going, The next thing I'll be doing is mounting the frame for railing, adding the cutter head, and making final adjustments.
This cutter is going to be the best, I gave it spliced wire audio inputs, 8 gauge wiring for the AC audio, four 100 amp fuses on each line, and will add in a couple ammeters to read amp reading during cutting. I'm working on the cutter ytoo, which has two electromagnets powered by Neodymium, the strongest magnetics on Earth. The voice coils I built are very small about an inch, and very loud from the magnets that amplify the electro-magnetic core about 1000x. I gave the unit handles on each side too so I could carry the CNC around!
I should have full frequency when finished, and figure I can get it to work with around 100 watts or less. I just put the huge fuses on to make the unit look cool when its built. Don't mind the messy wires, they'll be bolted down very soon. Not to mention I took the tonarm aoff, when the CNC is done, The cutter will take up its space.
Update to follow.
Tweakie.CNC
Active Member
Offline
Super Kitty.
Re: CNC Record Cutting Lathe
Reply #1 on:
March 27, 2011, 03:48:49 AM »
Sounds like an interesting project - looking forward to seeing how this turns out.
Success consists of going from failure to failure without loss of enthusiasm. Winston Churchill.
JungleStreetRecords
Active Member
Offline
Reply #2 on:
March 27, 2011, 03:59:00 AM »
Me too. This is my dream machine right here. Even dream about it when I sleep so I guess if I build it, they will come and want their dub plates made.
I have a set of Nema 17's and will run them at 1/16 microstep. 0.30" inches per minute on X.
The math is intense, but I'm getting the hang of it.
In the end, I figured 45 minutes of audio on each side of a 12".
Last Edit: March 27, 2011, 04:10:59 AM by JungleStreetRecords
ostie01
Active Member
Offline
Reply #3 on:
March 27, 2011, 04:07:03 AM »
Do you have any examples of how it work.
You talk about cutter, do you have picture of it.
Would be interested to see it in action
Jeff
JungleStreetRecords
Active Member
Offline
Reply #4 on:
March 27, 2011, 04:16:28 AM »
I'll have video as soon as its built. For now, the cutterhead is all in pieces until I can build the Z axis tool holder.
I'm designing a sled to be compatible with all 3 XY and Z axes. All in one.
The electromags will be aimed at a diamond stylus 45 degrees each side to provide stereo,
and the stylus will be be held at 88 degrees from the blanks to help minimize dulling the stylus.
JungleStreetRecords
Active Member
Offline
Reply #5 on:
March 27, 2011, 04:23:51 AM »
Run the audio from amp through the electromagnets, but add your Ohmage resistance so you don't kill your amplifier.
a cutter would be something along the lines of this:
JungleStreetRecords
Active Member
Offline
Reply #6 on:
March 27, 2011, 04:29:48 AM »
With an electromagnet mounted on each side of the cutter head. Wrap 22 gauge enamel coated copper wire around these, and you have a very powerful electromag that will vibrate the stylus when you cut the groove. For mine, I placed the magnets on the ouside of the coils, leaving the cores bare aluminum.
You can probably just use a machine screw and it might still work.
JungleStreetRecords
Active Member
Offline
Reply #7 on:
March 27, 2011, 04:32:46 AM »
with the audio from the amp being AC current, the aluminum cores become energized and interact with the Neodymium magnets.
ostie01
Active Member
Offline
Reply #8 on:
March 27, 2011, 04:46:57 AM »
Thanks for the info.
Jeff
Pages:
1
Go Up
« previous
next »
Jump to:
Please select a destination:
Mach Discussion
=> General Mach Discussion
=> Mach3 under Vista
=> Quantum
=> Brains Development
=> Video P*r*o*b*i*n*g
=> Mach Screens
===> Works in progress
===> Finished Screens
===> Flash Screens
===> JetCam screen designer
===> CVI MachStdMill (MSM)
=> Feature Requests
=> Non English Forums
===> Italian
===> French
===> Spanish
===> Chinese
===> German
===> Russian
===> Romanian
===> Japanese
===> Vietnamese
=> FAQs
*****VIDEOS*****
=> *****VIDEOS*****
General CNC Chat
=> Share Your GCode
G-Code, CAD, and CAM
=> LazyCam (Beta)
=> LazyTurn
=> Tempest Trajectory Planner
=> Contec
=> dspMC/IP Motion Controller
=> HiCON Motion Controller
=> Galil
=> Newfangled Solutions Wizards
=> Mach3 and G-Rex
=> Mesa
=> Modbus
=> NC Pod
=> PoKeys
=> SmoothStepper USB
=> Sieg Machines
Tangent Corner
=> Tangent Corner
=> Competitions
=> Polls
=> Bargain Basement
Support
=> Downloads
===> XML files
===> Post Processors
===> Macros
===> Tutorials
===> Others
===> Beta Brains
===> Screen Sets
===> Documents
===> MACH TOOL BOX
=> One on one phone support.
Mach4
=> Mach4 pre-Alpha Testing
Loading...
