Hello
Guest
it is
June 09, 2026, 02:00:04 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
Spindle
« previous
next »
Print
Pages:
1
2
3
Go Down
Author
Topic: Spindle (Read 29627 times)
jr_82
29
Re: Spindle
Reply #20 on:
March 22, 2011, 03:37:30 PM »
• Relay spindle interface - Outputs Max. 36V 7.5A for spindle motors or coolant pump (only one
device can be powered by this output!)
So does this mean it will put out 36v to run the spindle. or just its max input.
Junior
Carnoustie, Scotland
Re: Spindle
Reply #21 on:
March 22, 2011, 03:46:00 PM »
It is just a relay but the Gnd has me wondering as I was expecting that to be the common terminal of a NC/NO relay.
What it sounds like is just a normally open relay and you would connect the positive supply to V+ and then V- to your motors positive. The Negative wire from your supply would go direct to the motor. However as said the Gnd has me slightly worried and if I could test myself I would be confident to tell you how to connect but as I cant then it might be best to see if you can ask the supplier of the board.
Re: Spindle
Reply #22 on:
March 22, 2011, 03:47:27 PM »
No it will not put out 36v, that means it will handle a max of 36v at 7.5 amps through its contacts, you need to supply the voltage for the contacts.
jr_82
29
Re: Spindle
Reply #23 on:
March 22, 2011, 03:54:19 PM »
OK thanks for all the help.
Junior
jr_82
29
Re: Spindle
Reply #24 on:
March 22, 2011, 04:04:41 PM »
Is there any way I can use this, to index. like a 4th axis?
Junior
Re: Spindle
Reply #25 on:
March 22, 2011, 04:10:08 PM »
Don think so unless you have a stand alone 4th axis that reqires a signal to make it index.
It is meant for coolant or spindle on/off like you say and I am almost certain it should be wired like I said two posts ago but as its not mine and I cant test I will not say it is definitely that way as I dont want to be responsible for you letting the smoke out.
Print
Pages:
1
2
3
Go Up
« previous
next »
