May 27, 2012, 06:34:51 PM
Search:     Advanced search
+  Machsupport Forum
|-+  Mach Discussion
| |-+  FAQs
| | |-+  Breakout board
Pages: 1   Go Down
Print
Author Topic: Breakout board  (Read 730 times)
jd1uth
Active Member
Offline Offline
View Profile
« on: March 20, 2011, 05:24:20 PM »
Hello All
I Do Need a breakout board there are so manny i do not now what ik must get i ask jou for advice on this what is the best choice
i whant a good board for 4 drives, limit and  home connectors.
jan
ostie01
Active Member
Offline Offline
View Profile
« Reply #1 on: March 20, 2011, 08:46:44 PM »
I would choose one with which you can select if pins 2 to 9 can be either inputs or outputs.
This leave you with more choice with the breakout board.
CNC4PC make good ones.
The C10 and C11 are very popular with Mach3 users.
I wanted to buy the C32 model but it is back order.
Also buy one that is fully opto isolated or one fully isolated (others method) to protect your computer
Jeff
Tweakie.CNC
Active Member
Offline Offline
Super Kitty.
View Profile WWW
« Reply #2 on: March 21, 2011, 02:43:10 AM »
Hi Jan,
The CNC4PC, C10 and C11 seem to have become the industry standard with good price and good quality as well as good back-up if you ever need it.
Success consists of going from failure to failure without loss of enthusiasm.  Winston Churchill.
jd1uth
Active Member
Offline Offline
View Profile
« Reply #3 on: March 23, 2011, 04:20:01 PM »
Thank for the replay i think i go for the C11
Tweakie.CNC
Active Member
Offline Offline
Super Kitty.
View Profile WWW
« Reply #4 on: March 24, 2011, 02:05:14 AM »
That would be my first choice as well.  Wink
jd1uth
Active Member
Offline Offline
View Profile
« Reply #5 on: March 27, 2011, 03:54:23 PM »
Are there any more options for a good breakout board.
bad manual for such a good looking card.
i read a lot of troble hook up the wirering  becourse of the bat manual.
Jan
« Last Edit: March 27, 2011, 03:57:48 PM by jd1uth » Logged
Pages: 1   Go Up
Print
Jump to:
