Home
Downloads
Mach3
Plugins
CAM Post Processors
Screensets
Purchase
Support
Forum
Tutorial Videos
Documentation
Yahoo Group
Mach Wiki
Resources
Contact Us
Links
CNCZone
German Forum
Italian Forum
Korean Forum
Portugese (Brazil) Forum
Russian Forum (RSK CNCROUTER)
Thai Forum
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email?
May 27, 2012, 06:16:11 PM
1 Hour
1 Day
1 Week
1 Month
Forever
Search:
Advanced search
Select from and to languages
Chinese-simp to English
Chinese-trad to English
English to Chinese-simp
English to Chinese-trad
English to Dutch
English to French
English to German
English to Greek
English to Italian
English to Japanese
English to Korean
English to Portuguese
English to Russian
English to Spanish
Dutch to English
Dutch to French
French to English
French to German
French to Greek
French to Italian
French to Portuguese
French to Dutch
French to Spanish
German to English
German to French
Greek to English
Greek to French
Italian to English
Italian to French
Japanese to English
Korean to English
Portuguese to English
Portuguese to French
Russian to English
Spanish to English
Spanish to French
Mach Discussion
General Mach Discussion
Zeroing Multiple Z Offsets
Pages:
1
Go Down
« previous
next »
Author
Topic: Zeroing Multiple Z Offsets (Read 333 times)
dfurlano
Active Member
Offline
on:
March 15, 2011, 04:57:03 PM »
I use the tool macro to set the Z offset:
Call setdro (2,platethickness)
This sets whatever offset you have enabled which is usually G54. But I would like to set multiple offsets at once like G54, G55, G56, and G57.
Is there are command that I can use to do this?
TIA
Dan.
ger21
Global Moderator
Offline
Re: Zeroing Multiple Z Offsets
Reply #1 on:
March 15, 2011, 05:06:22 PM »
I do it this way. After zeroing in the current offset, I retrieve that offset and change the other's to match.
CurrentOffset = GetOEMDRO(46) ' Get Current Coordinate system 1 = G54, 2 = G55, ....
If CurrentOffset = 1 Then
ZOffset=GetVar(5223)
ElseIf CurrentOffset = 2 Then
ZOffset=GetVar(5243)
ElseIf CurrentOffset = 3 Then
ZOffset=GetVar(5263)
ElseIf CurrentOffset = 4 Then
ZOffset=GetVar(5283)
ElseIf CurrentOffset = 5 Then
ZOffset=GetVar(5303)
ElseIf CurrentOffset = 6 Then
ZOffset=GetVar(5323)
End If
For X = 5223 To 5323 Step 20
SetVar(X, ZOffset)
Next X
Sleep(250)
http://home.comcast.net/~cncwoodworker/2010.html
dfurlano
Active Member
Offline
Reply #2 on:
March 15, 2011, 07:00:31 PM »
For some reason this does not work... G54 gets set to the correct value but the others are all off by some offset. I tried zeroing all the values in the tool table before I started but that did not work. I also tried adding a call and a code in front of the setvar and that did nothing.
CurrentFeed = GetOemDRO(818) 'Get the current feedrate to return to later
CurrentAbsInc = GetOemLED(48) 'Get the current G90/G91 state
CurrentGmode = GetOemDRO(819) 'Get the current G0/G1 state
PlateThickness = GetUserDRO(1151) 'Z-plate thickness DRO
DoOEMButton (1010) 'zero the Z axis so the probe move will start from here
Code "G4 P2" ' this delay gives me time to get from computer to hold probe in place
Code "G90 G31 Z-1 F5" 'probing move, can set the feed rate here as well as how far to move
While IsMoving() 'wait while it happens
Wend
ZProbePos = GetVar(2002) 'get the axact point the probe was hit
Code "G0 Z" &ZProbePos 'go back to that point, always a very small amount of overrun
While IsMoving ()
Wend
Call SetDro (2, PlateThickness) 'set the Z axis DRO to whatever is set as plate thickness
Code "G4 P0.25" 'Pause for Dro to update.
SetVar(5243, PlateThickness)
SetVar(5263, PlateThickness)
SetVar(5283, PlateThickness)
While IsMoving ()
Wend
Code "(Z axis is now zeroed)" 'puts this message in the status bar
Code "F" &CurrentFeed 'Returns to prior feed rate
If CurrentAbsInc = 0 Then 'if G91 was in effect before then return to it
Code "G91"
End If
If CurrentGMode = 0 Then 'if G0 was in effect before then return to it
Code "G0"
End If
Exit Sub
Last Edit: March 15, 2011, 07:02:25 PM by dfurlano
dfurlano
Active Member
Offline
Reply #3 on:
March 15, 2011, 07:15:20 PM »
When I look in the Mach3 manual in section 10 is says that variable 5244 is offset 2 Z, then 5263 is offset 3 Z, and 5283 is offset 4 Z.
ger21
Global Moderator
Offline
Reply #4 on:
March 15, 2011, 07:17:39 PM »
Your code works fine, but you're not setting the right value.
The Plate Thickness is not the offset. When you set the Z DRO to the plate thickness, the offset is the current machine coordinate - plate thickness.
For your other offsets, you're just setting the plate thickness.
That's why I read the actual offset from the current coordinate system, then assign that actual offset to the other coordinate systems.
ger21
Global Moderator
Offline
Reply #5 on:
March 15, 2011, 07:18:31 PM »
That's a typo in the manual, it's 5243.
dfurlano
Active Member
Offline
Reply #6 on:
March 15, 2011, 07:34:34 PM »
Thank you.
Pages:
1
Go Up
« previous
next »
Jump to:
Please select a destination:
Mach Discussion
=> General Mach Discussion
=> Mach3 under Vista
=> Quantum
=> Brains Development
=> Video P*r*o*b*i*n*g
=> Mach Screens
===> Works in progress
===> Finished Screens
===> Flash Screens
===> JetCam screen designer
===> CVI MachStdMill (MSM)
=> Feature Requests
=> Non English Forums
===> Italian
===> French
===> Spanish
===> Chinese
===> German
===> Russian
===> Romanian
===> Japanese
===> Vietnamese
=> FAQs
*****VIDEOS*****
=> *****VIDEOS*****
General CNC Chat
=> Share Your GCode
G-Code, CAD, and CAM
=> LazyCam (Beta)
=> LazyTurn
=> Tempest Trajectory Planner
=> Contec
=> dspMC/IP Motion Controller
=> HiCON Motion Controller
=> Galil
=> Newfangled Solutions Wizards
=> Mach3 and G-Rex
=> Mesa
=> Modbus
=> NC Pod
=> PoKeys
=> SmoothStepper USB
=> Sieg Machines
Tangent Corner
=> Tangent Corner
=> Competitions
=> Polls
=> Bargain Basement
Support
=> Downloads
===> XML files
===> Post Processors
===> Macros
===> Tutorials
===> Others
===> Beta Brains
===> Screen Sets
===> Documents
===> MACH TOOL BOX
=> One on one phone support.
Mach4
=> Mach4 pre-Alpha Testing
Loading...
