Home
Downloads
Mach3
Plugins
CAM Post Processors
Screensets
Purchase
Support
Forum
Tutorial Videos
Documentation
Yahoo Group
Mach Wiki
Resources
Contact Us
Links
CNCZone
German Forum
Italian Forum
Korean Forum
Portugese (Brazil) Forum
Russian Forum (RSK CNCROUTER)
Thai Forum
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email?
May 27, 2012, 06:11:41 PM
1 Hour
1 Day
1 Week
1 Month
Forever
Search:
Advanced search
Select from and to languages
Chinese-simp to English
Chinese-trad to English
English to Chinese-simp
English to Chinese-trad
English to Dutch
English to French
English to German
English to Greek
English to Italian
English to Japanese
English to Korean
English to Portuguese
English to Russian
English to Spanish
Dutch to English
Dutch to French
French to English
French to German
French to Greek
French to Italian
French to Portuguese
French to Dutch
French to Spanish
German to English
German to French
Greek to English
Greek to French
Italian to English
Italian to French
Japanese to English
Korean to English
Portuguese to English
Portuguese to French
Russian to English
Spanish to English
Spanish to French
Mach Discussion
General Mach Discussion
Stepper motor working in 1 direction only!
Pages:
1
Go Down
« previous
next »
Author
Topic: Stepper motor working in 1 direction only! (Read 426 times)
davidc
Active Member
Offline
on:
March 15, 2011, 06:32:58 AM »
Hi All, new to MACH3 & CNC control in general, so hoping I've just got something silly wrong here!
I've got a stepper motor (Bipolar) connected to a Parker XL25 driver, connected to my PC & MACH3.
The driver can operate in 2 modes, Step/Direction, or Step+/Step- mode.
wired for step/direction, I have ports 1&2 on the LPT connected to the corresponding step/dir ports on the driver, but although the motor powers on I get no motion.
Someone suggested that by switching to Step+/Step- mode (there is a DIP switch on the driver to do this) and just wiring the Step- & Dir - pins on the driver together it would work.
Now I get motion in one direction only (presumably caused by the inputs on the Step+ & Dir+ pins, but lacking any input on the Step- & Dir - pins)
Is it possible to configure MACH3 to operate in this Step+/Step- mode, or any trick to get the Step/Dir mode working?
Many thanks for any help - much appreciated!
Dave.
Tweakie.CNC
Active Member
Offline
Super Kitty.
Re: Stepper motor working in 1 direction only!
Reply #1 on:
March 15, 2011, 08:09:35 AM »
Hi David,
Welcome to the forum.
I have not actually used the XL25 I am just going by the manual but it would seem that the XL25 inputs should be connected;
Pin 1 to computer LPT pin 2
Pin 2 to computer LPT pin 3
Pin 6 GND
Pin 7 GND
And mach configured (active high) something similar to attachment (it is not usual to use Pin1 of the computer LPT port for step and direction signals)
Now this should work but it is not the preferred way to do it because the computer’s LPT port can sink more current than it can source. Either (a) connect Pins 1 and 2 of the XL25 through current limiting resistors to +5 volts and use pins 6 and 7 as active low inputs from the LPT port pins 2 and 3 or (b) use an active breakout board which can provide the TTL level signals to the XL25 without loading the LPT parallel port.
Last Edit: March 15, 2011, 08:23:15 AM by Tweakie.CNC
Success consists of going from failure to failure without loss of enthusiasm. Winston Churchill.
Active Member
Offline
Carnoustie, Scotland
Reply #2 on:
March 15, 2011, 08:35:09 AM »
Personally I would make up (or you could buy) a line driver to change the Step/Dir single ended signals out of the PP into Differential.
davidc
Active Member
Offline
Reply #3 on:
March 15, 2011, 08:42:56 AM »
Thanks for the replies!
Will have a go at shifting the pin assignments to 2&3, though should it make much difference if I've specified pins 1&2 in the outputs of MACH3?
When you say pins 6&7 to GND, is that simply left disconnected, or is there a specific place/pin I should attach those wires to?
Sorry if the questions sound stupid, this electrickery is all new to me!
Many thanks,
Dave.
Tweakie.CNC
Active Member
Offline
Super Kitty.
Reply #4 on:
March 15, 2011, 08:50:21 AM »
Dave,
Pins 6 & 7 are the low end of the opto isolator circuits and they should be connected to Ground or 0 Volts (pins 18-25 of the LPT port if you are not using a breakout board or 0 Volts of the active breakout board supply).
Last Edit: March 15, 2011, 08:56:31 AM by Tweakie.CNC
davidc
Active Member
Offline
Reply #5 on:
March 15, 2011, 09:02:46 AM »
Thanks for the edit, just had to google that one ;-)
Will have a go at that now & see how it goes!
Cheers,
Dave.
davidc
Active Member
Offline
Reply #6 on:
March 15, 2011, 10:18:06 AM »
Many thanks for the help guys, thats working perfectly now!
Pages:
1
Go Up
« previous
next »
Jump to:
Please select a destination:
Mach Discussion
=> General Mach Discussion
=> Mach3 under Vista
=> Quantum
=> Brains Development
=> Video P*r*o*b*i*n*g
=> Mach Screens
===> Works in progress
===> Finished Screens
===> Flash Screens
===> JetCam screen designer
===> CVI MachStdMill (MSM)
=> Feature Requests
=> Non English Forums
===> Italian
===> French
===> Spanish
===> Chinese
===> German
===> Russian
===> Romanian
===> Japanese
===> Vietnamese
=> FAQs
*****VIDEOS*****
=> *****VIDEOS*****
General CNC Chat
=> Share Your GCode
G-Code, CAD, and CAM
=> LazyCam (Beta)
=> LazyTurn
=> Tempest Trajectory Planner
=> Contec
=> dspMC/IP Motion Controller
=> HiCON Motion Controller
=> Galil
=> Newfangled Solutions Wizards
=> Mach3 and G-Rex
=> Mesa
=> Modbus
=> NC Pod
=> PoKeys
=> SmoothStepper USB
=> Sieg Machines
Tangent Corner
=> Tangent Corner
=> Competitions
=> Polls
=> Bargain Basement
Support
=> Downloads
===> XML files
===> Post Processors
===> Macros
===> Tutorials
===> Others
===> Beta Brains
===> Screen Sets
===> Documents
===> MACH TOOL BOX
=> One on one phone support.
Mach4
=> Mach4 pre-Alpha Testing
Loading...
