Hello Guest it is June 09, 2026, 09:53:14 AM
Author Topic: Text Message  (Read 7751 times)
Text Message
« on: March 14, 2011, 07:15:53 PM »
Anyone ever write a VB script to send a text message to a phone via the internet?
Re: Text Message
« Reply #1 on: March 14, 2011, 08:52:19 PM »
YES, I will have to look it up and post it later. It works very well to keep you up to date on long runs
OK HERE YOU GO, Your machine can call home. You wil have to fill in the account info stuff to math your settings and password.
'M3030 Macro
Message " MACHINE #549, Process COMPLETED Call Home"
Const cdoSendUsingPickup = 1 'Send message using the local SMTP service pickup directory.
Const cdoSendUsingPort = 2 'Send the message using the network (SMTP over the network).
Const cdoAnonymous = 0 'Do not authenticate
Const cdoBasic = 1 'basic (clear-text) authentication
Const cdoNTLM = 2 'NTLM
Set objMessage = CreateObject("CDO.Message")
objMessage.Subject = "Machine Alert"
objMessage.From = """Machine #549"" <Machine#549@BR549.com>"
objMessage.To = "YOUR EMAIL ADDRESS.com"
objMessage.TextBody = "Machine #549 Process Completed.." & vbCRLF & "Thank You(;-)"
'==This section provides the configuration information for the remote SMTP server.
objMessage.Configuration.Fields.Item _
("http://schemas.microsoft.com/cdo/configuration/sendusing") = 2
'Name or IP of Remote SMTP Server
("http://schemas.microsoft.com/cdo/configuration/smtpserver") = "YOUR SMTP SERVER NAME"
'Type of authentication, NONE, Basic (Base64 encoded), NTLM
("http://schemas.microsoft.com/cdo/configuration/smtpauthenticate") = cdoBasic
'Your UserID on the SMTP server
("http://schemas.microsoft.com/cdo/configuration/sendusername") = "YOU ACCOUNT NAME ON THE SERVER"
'Your password on the SMTP server
("http://schemas.microsoft.com/cdo/configuration/sendpassword") = "YOU ACCOUNT PASSWORD"
'Server port (typically 25)
("http://schemas.microsoft.com/cdo/configuration/smtpserverport") = 25
'Use SSL for the connection (False or True)
("http://schemas.microsoft.com/cdo/configuration/smtpusessl") = False
'Connection Timeout in seconds (the maximum time CDO will try to establish a connection to the SMTP server)
("http://schemas.microsoft.com/cdo/configuration/smtpconnectiontimeout") = 60
objMessage.Configuration.Fields.Update
'==End remote SMTP server configuration section==
objMessage.Send
End
« Last Edit: March 14, 2011, 09:03:21 PM by BR549 »
Re: Text Message
« Reply #2 on: March 14, 2011, 09:14:10 PM »
Thanks!
Re: Text Message
« Reply #3 on: March 15, 2011, 08:58:21 AM »
objMessage.From = """Machine #549"" <Machine#549@BR549.com>"            <-------------------------------- I am assuming here you put your email address
objMessage.To = "YOUR EMAIL ADDRESS.com"                              <------- and here you put your phone number? *********@vtext.com
« Last Edit: March 15, 2011, 09:00:03 AM by dfurlano »
Re: Text Message
« Reply #4 on: March 15, 2011, 10:31:00 AM »
BTW:
The above does work with a Verizon cell phone *********@vtext.com
The standard port has now changed from port 25 to 587
Thanks again.
