Hello
Guest
it is
June 09, 2026, 09:52:43 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
VB and the development of wizards
Text Message
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Text Message (Read 7749 times)
dfurlano
252
Text Message
on:
March 14, 2011, 07:15:53 PM »
Anyone ever write a VB script to send a text message to a phone via the internet?
BR549
6,965
Re: Text Message
Reply #1 on:
March 14, 2011, 08:52:19 PM »
YES, I will have to look it up and post it later. It works very well to keep you up to date on long runs
OK HERE YOU GO, Your machine can call home. You wil have to fill in the account info stuff to math your settings and password.
'M3030 Macro
Message " MACHINE #549, Process COMPLETED Call Home"
Const cdoSendUsingPickup = 1 'Send message using the local SMTP service pickup directory.
Const cdoSendUsingPort = 2 'Send the message using the network (SMTP over the network).
Const cdoAnonymous = 0 'Do not authenticate
Const cdoBasic = 1 'basic (clear-text) authentication
Const cdoNTLM = 2 'NTLM
Set objMessage = CreateObject("CDO.Message")
objMessage.Subject = "Machine Alert"
objMessage.From = """Machine #549"" <Machine#549@BR549.com>"
objMessage.To = "YOUR EMAIL ADDRESS.com"
objMessage.TextBody = "Machine #549 Process Completed.." & vbCRLF & "Thank You(;-)"
'==This section provides the configuration information for the remote SMTP server.
objMessage.Configuration.Fields.Item _
http://schemas.microsoft.com/cdo/configuration/sendusing
") = 2
'Name or IP of Remote SMTP Server
http://schemas.microsoft.com/cdo/configuration/smtpserver
") = "YOUR SMTP SERVER NAME"
'Type of authentication, NONE, Basic (Base64 encoded), NTLM
http://schemas.microsoft.com/cdo/configuration/smtpauthenticate
") = cdoBasic
'Your UserID on the SMTP server
http://schemas.microsoft.com/cdo/configuration/sendusername
") = "YOU ACCOUNT NAME ON THE SERVER"
'Your password on the SMTP server
http://schemas.microsoft.com/cdo/configuration/sendpassword
") = "YOU ACCOUNT PASSWORD"
'Server port (typically 25)
http://schemas.microsoft.com/cdo/configuration/smtpserverport
") = 25
'Use SSL for the connection (False or True)
http://schemas.microsoft.com/cdo/configuration/smtpusessl
") = False
'Connection Timeout in seconds (the maximum time CDO will try to establish a connection to the SMTP server)
http://schemas.microsoft.com/cdo/configuration/smtpconnectiontimeout
") = 60
objMessage.Configuration.Fields.Update
'==End remote SMTP server configuration section==
objMessage.Send
End
Last Edit: March 14, 2011, 09:03:21 PM by BR549
dfurlano
252
Re: Text Message
Reply #2 on:
March 14, 2011, 09:14:10 PM »
Thanks!
dfurlano
252
Re: Text Message
Reply #3 on:
March 15, 2011, 08:58:21 AM »
<-------------------------------- I am assuming here you put your email address
<------- and here you put your phone number? *********@vtext.com
Last Edit: March 15, 2011, 09:00:03 AM by dfurlano
dfurlano
252
Re: Text Message
Reply #4 on:
March 15, 2011, 10:31:00 AM »
BTW:
The above does work with a Verizon cell phone *********@vtext.com
The standard port has now changed from port 25 to 587
Thanks again.
Print
Pages:
1
Go Up
« previous
next »
