Im considering making an aditional axis for boring holes.
Basically a CNC controlled boring bar that allows the diameters to be changed fromt he Gcode
The way Im think is having the boring tip on an angled slide so as its moved down the tip moves out (away from the centerline).
The problem will be the z position will also move with the change in diameter.
Is there a way of linking the 2 axis so as the tip moves in/out a formula is applied to the z axis to keep it in the correct position.
Is this possible with a Brain or is it going to involve some complicated Gcode?
