May 27, 2012, 06:03:58 PM
Search:     Advanced search
+  Machsupport Forum
|-+  Mach Discussion
| | |-+  XML change for Gecko
Pages: « 1 2   Go Down
Print
Author Topic: XML change for Gecko  (Read 528 times)
sawduststeve
Active Member
Offline Offline
View Profile
« Reply #10 on: March 13, 2011, 02:49:59 PM »
Hood,
BTW - What did changing the xml to IJMode 1 actually do?
Steve.
Active Member
Offline Offline
Carnoustie, Scotland
View Profile
« Reply #11 on: March 13, 2011, 02:54:19 PM »
The code will run fine as long as the mode defined in the preamble is what the code is written in.
For example say Mach is set as default G90 (Abs distance) and G90.1 (Abs IJ) and your code was written in incremental for both then as long as you code had G91 and G91.1 in the preamble things would run fine. If however your code did not specify which modes to run in then Mach would try and run them in the mode it is presently in.
Active Member
Offline Offline
View Profile
« Reply #12 on: March 13, 2011, 02:55:38 PM »
Changing the IJ mode in the xml just changed the IJ mode from Abs to Inc.
Pages: « 1 2   Go Up
Print
Jump to:
