May 27, 2012, 05:57:41 PM
Search:     Advanced search
+  Machsupport Forum
|-+  Mach Discussion
| | |-+  Mach3 behaving strangely
Pages: « 1 2   Go Down
Print
Author Topic: Mach3 behaving strangely  (Read 656 times)
Overloaded
Global Moderator
Offline Offline
View Profile
« Reply #10 on: March 12, 2011, 10:57:24 AM »
Hi Scott, you have A slaved to X and A set as Angular.
Is this intentional ?
My guess, it's hung up in the homing routine like Hood mentioned as A is never getting referenced.
Home slave with masrer is also checked.
Un-slaved A and it appears to work normally now in sim.
Russ
« Last Edit: March 12, 2011, 11:01:36 AM by Overloaded » Logged
"I haven't failed. I've just found 10,000 ways that won't work."         Edison
"You cannot help men permanently by doing for them what they could and should do for themselves."
Abe Lincoln
Active Member
Offline Offline
Carnoustie, Scotland
View Profile
« Reply #11 on: March 12, 2011, 11:02:15 AM »
Sorry had someone come in. Yes I think that is the problem.
ssutton
Active Member
Offline Offline
View Profile
« Reply #12 on: March 12, 2011, 11:18:50 AM »
OK,
Sounds like you guys are on to something here. Please help me set up my machine correctly.
I have A slaved to X because I have 2 motors on my X axis. However, I currently have only 1 home sensor on my X axis. What I will do (I have ordered the parts) when I get the parts is have 2 home sensors on 2 separate inputs so that I can "square" my gantry with a homing routine.
But, currently I have only 1 home sensor for the X. I am confused about slaving, when I first set up my machine I slaved A to X and the machine would jog via the keyboard normally, BUT, when I clicked ref all home only 1 of the X motors would run and the gantry would try to twist until it stalled. I posted a question about this on another CNC forum and was told to check "Home slave with master axis", this seemed to fix my problem because now both motors run when I home. But it has caused this issue.
So what am I to configure to get it to run correctly  with the 1 X axis sensor that I have now?
What am I to configure when I get the second home sensor  and  i want to square my gantry with it?
Thanks guys,
Scott
Active Member
Offline Offline
View Profile
« Reply #13 on: March 12, 2011, 11:21:53 AM »
Yes because you have the A home switch enabled, disable it and all should be fine.
Overloaded
Global Moderator
Offline Offline
View Profile
« Reply #14 on: March 12, 2011, 11:26:44 AM »
Uncheck A as Angular
disable the HOME swit for A in Ports and pins/input signals
check Home slave with master
 when you get the second sensor, install and enable it in config
Abe Lincoln
ssutton
Active Member
Offline Offline
View Profile
« Reply #15 on: March 12, 2011, 11:46:52 AM »
Wow! Thanks, I am a total newbie and just could not figure this out. That solved my issue and shed light about the way that Mach "thinks". That seems to be the largest problem of learning new software is getting your head wrapped around the logic.
Thanks again to all who shared your time with me.
-Scott
Overloaded
Global Moderator
Offline Offline
View Profile
« Reply #16 on: March 12, 2011, 11:48:07 AM »
 Smiley
The learning is never ending.
Glad we were able to help.
 Smiley
Abe Lincoln
Pages: « 1 2   Go Up
Print
Jump to:
