Hello Guest it is June 12, 2026, 06:56:59 PM
Author Topic: Mach3 manual says there is a DXF import feature but?????  (Read 8909 times)
Offline sn96
  •  60 60
« on: March 10, 2011, 08:07:58 AM »
Hello guys,
I have the lockdown version of Mach3 and I don't see anywhere where you can import DXF files like the manual describes. Was this feature removed? if so, why?
Mike
________________________________
PM25mv with Arizona cnc conversion kit
windows 10
i7 laptop
mach3 demo latest version
stepperonline 566 ozin closed loop stepper 4.0 driver for x and y
stepperonline 1699 ozin closed loop stepper 4.0 driver for the z
amazon no name brand usb controller
Re: Mach3 manual says there is a DXF import feature but?????
« Reply #1 on: March 10, 2011, 08:59:26 AM »
« Last Edit: March 10, 2011, 09:10:42 AM by Overloaded »
  •  9,356 9,356
« Reply #2 on: March 10, 2011, 09:15:34 AM »
Obviously the manual is not up to date with the latest version of Mach.
The direct .dfx import was removed from the menu long ago in favour of LazyCam which does the same job only better and with more options. I think that it was then envisaged that LazyCam would continue to be developed though.
Offline sn96
  •  60 60
« Reply #3 on: March 10, 2011, 05:25:52 PM »
From a quick search "DXF Import"
http://www.machsupport.com/forum/index.php/topic,16616.0.html
http://www.machsupport.com/forum/index.php/topic,1642.0.html
MUCH more there if you are interested.
Russ
Thanks, perhaps a quick search would have been the thing to do first.
Mike
windows 10
i7 laptop
