Home
Downloads
Mach3
Plugins
CAM Post Processors
Screensets
Purchase
Support
Forum
Tutorial Videos
Documentation
Yahoo Group
Mach Wiki
Resources
Contact Us
Links
CNCZone
German Forum
Italian Forum
Korean Forum
Portugese (Brazil) Forum
Russian Forum (RSK CNCROUTER)
Thai Forum
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email?
May 27, 2012, 05:30:20 PM
1 Hour
1 Day
1 Week
1 Month
Forever
Search:
Advanced search
Select from and to languages
Chinese-simp to English
Chinese-trad to English
English to Chinese-simp
English to Chinese-trad
English to Dutch
English to French
English to German
English to Greek
English to Italian
English to Japanese
English to Korean
English to Portuguese
English to Russian
English to Spanish
Dutch to English
Dutch to French
French to English
French to German
French to Greek
French to Italian
French to Portuguese
French to Dutch
French to Spanish
German to English
German to French
Greek to English
Greek to French
Italian to English
Italian to French
Japanese to English
Korean to English
Portuguese to English
Portuguese to French
Russian to English
Spanish to English
Spanish to French
Mach Discussion
General Mach Discussion
Spindle speed varies when moving axis
Pages:
1
Go Down
« previous
next »
Author
Topic: Spindle speed varies when moving axis (Read 374 times)
frogeye
Active Member
Offline
on:
March 06, 2011, 04:56:43 AM »
Hi All,
I've just replaced my CNC4PC 11G breakout board following a failure of the original.
When I move the axis (Z or X), the spindle speed increases. The amount the speed increases seems to depend on the speed of the axis, with about a 500 rpm increase when rapiding.
The problem was not there before the board failed, but that was about 18 months ago.
I have tried changing settings in 'ports and pins' for the X and Z axis as I recall that that might be a fix, but no joy.
I'm using the 0-10v analogue output from the 11G to a Mitsubishi VFD.
Has anyone experienced this problem or know of a fix?
Cheers,
Paul
Active Member
Offline
Carnoustie, Scotland
Re: Spindle speed varies when moving axis
Reply #1 on:
March 06, 2011, 05:28:36 AM »
Try increaing the Step Pulse and Dir Pulse to 5 if not already done.
ger21
Global Moderator
Offline
Reply #2 on:
March 06, 2011, 06:54:09 AM »
Are your steppers wires possibly introducing noise into the 0-10V line?
http://home.comcast.net/~cncwoodworker/2010.html
Tweakie.CNC
Active Member
Offline
Super Kitty.
Reply #3 on:
March 06, 2011, 07:15:13 AM »
Paul,
I trust you set up the spindle output according to the instructions.
I am sure you did but it is just a thought.
Success consists of going from failure to failure without loss of enthusiasm. Winston Churchill.
frogeye
Active Member
Offline
Reply #4 on:
March 06, 2011, 08:47:54 PM »
Ho All,
thanks for your replies.
I've had another look this morning and tried your suggestion Hood - unfortunately, it didn't make a difference.
Gerry,
I don't think it's noise from the steep/direction lines to the stepper drives. I've used a good quality screened pair cable that has been grounded in the middle of it's length.
Tweekie, I've rechecked the setup - I can get a stable and proportional signal on the 0-10v connection. When rapiding, this value increases. e.g. 5v at 1000 rpm. Rapiding increase this to about 7v and 1440 rpm.
I've monitored the 5 and 12 volt supplies with a DVM, and these look rock steady.
Enabling spindle feedback control works - sort of! Ther's a momentary change of speed at the start and end of a rapid movement, while the controller gets a grip. But I feel this is fixing the symptoms rather than the problem....
Has anyone seen this sort of fault before?
Paul
Tweakie.CNC
Active Member
Offline
Super Kitty.
Reply #5 on:
March 07, 2011, 03:20:39 AM »
Paul,
As the previous worked OK and this one doesn't it sounds as though you should be talking to CNC4PC as they may have made subtle changes to this function when introducing the later version board.
If you have, or know someone who has, an oscilloscope you could monitor the signal from Mach to the board and see if there is any fluctuation there that could be causing the speed variation.
frogeye
Active Member
Offline
Re: Spindle speed varies when moving axis - resolved
Reply #6 on:
March 16, 2011, 04:10:23 PM »
Hi All,
Just a quick update to let you know the current position.
After a number of emails with Arturo from CNC4PC, the board is being returned as faulty. No amount of tweeking or reseating of chips made the slightest difference.
The replacement boards are from Peter Homman.
Paul
Pages:
1
Go Up
« previous
next »
Jump to:
Please select a destination:
Mach Discussion
=> General Mach Discussion
=> Mach3 under Vista
=> Quantum
=> Brains Development
=> Video P*r*o*b*i*n*g
=> Mach Screens
===> Works in progress
===> Finished Screens
===> Flash Screens
===> JetCam screen designer
===> CVI MachStdMill (MSM)
=> Feature Requests
=> Non English Forums
===> Italian
===> French
===> Spanish
===> Chinese
===> German
===> Russian
===> Romanian
===> Japanese
===> Vietnamese
=> FAQs
*****VIDEOS*****
=> *****VIDEOS*****
General CNC Chat
=> Share Your GCode
G-Code, CAD, and CAM
=> LazyCam (Beta)
=> LazyTurn
=> Tempest Trajectory Planner
=> Contec
=> dspMC/IP Motion Controller
=> HiCON Motion Controller
=> Galil
=> Newfangled Solutions Wizards
=> Mach3 and G-Rex
=> Mesa
=> Modbus
=> NC Pod
=> PoKeys
=> SmoothStepper USB
=> Sieg Machines
Tangent Corner
=> Tangent Corner
=> Competitions
=> Polls
=> Bargain Basement
Support
=> Downloads
===> XML files
===> Post Processors
===> Macros
===> Tutorials
===> Others
===> Beta Brains
===> Screen Sets
===> Documents
===> MACH TOOL BOX
=> One on one phone support.
Mach4
=> Mach4 pre-Alpha Testing
Loading...
