May 27, 2012, 05:20:47 PM
Search:     Advanced search
+  Machsupport Forum
|-+  Third party software and hardware support forums.
| |-+  SmoothStepper USB (Moderator: Warp9TD)
| | |-+  Change speed while jogging
Pages: 1   Go Down
Print
Author Topic: Change speed while jogging  (Read 428 times)
Userli
Active Member
Offline Offline
View Profile
« on: March 04, 2011, 12:40:22 PM »
I developed a USB pendant, which allows to change the jogging speed by changing the MaxVelocity setting, while jogging. This works fine with the printer port driver but the SS only starts jogging with the initial speed and then continues at that speed, ignoring the changes.
Does anybody know, how to fix this?
Code:
Start jogging:
      Engine->Axis[ joyAxis].Dec = false;
      Engine->Axis[ joyAxis].Jogging = true;
      Code("DOJOG");
Change speed:
   Engine->Axis[ joyAxis].MaxVelocity =  newSpeedVal;
The code is called from within myHighspeedUpdate .
Frank.
Userli
Active Member
Offline Offline
View Profile
« Reply #1 on: March 04, 2011, 04:18:35 PM »
I'll answer myself in case somebody else has the same problem. A google search for code("ENDJOG") brought up that yahoo thread
http://groups.yahoo.com/group/mach1mach2cnc/message/80261
where Art explains how to do this.
Frank.
Pages: 1   Go Up
Print
Jump to:
