May 27, 2012, 05:14:32 PM
Search:     Advanced search
+  Machsupport Forum
|-+  Third party software and hardware support forums.
| |-+  Mach3 and G-Rex
| | |-+  Mach3 Probe Emulation Need Help
Pages: 1   Go Down
Print
Author Topic: Mach3 Probe Emulation Need Help  (Read 1022 times)
gauthib12
Active Member
Offline Offline
View Profile
« on: March 03, 2011, 06:06:18 PM »
Help! Huh
I have been trying to get my homebuilt probe working for some time without luck, I am sure I now have the wiring right but the probe routine doesn't work.  I have reverted to testing by using a key to simulate the probe tripping under inputs using emulation,  however I tried assigning P and when I press the P key the led does not light up?  Anyone have this problem? I have also tried other keys same problem?
ger21
Global Moderator
Offline Offline
View Profile WWW
« Reply #1 on: March 03, 2011, 07:04:50 PM »
I use this all the time for testing and mine works fine. I have it assigned to the "/" key.
gauthib12
Active Member
Offline Offline
View Profile
« Reply #2 on: March 03, 2011, 08:12:48 PM »
hmm ..tried this on a new machine and it works fine wonder if it's the computer giving me all the grief?
Pages: 1   Go Up
Print
Jump to:
