May 27, 2012, 04:57:52 PM
Search:     Advanced search
+  Machsupport Forum
|-+  Third party software and hardware support forums.
| |-+  SmoothStepper USB (Moderator: Warp9TD)
| | |-+  Max Servo speed
Pages: 1   Go Down
Print
Author Topic: Max Servo speed  (Read 534 times)
OzzieII
Active Member
Offline Offline
View Profile
« on: March 01, 2011, 03:17:31 PM »
Is it possible for SS to drive a servo motor at a speed greater than the nameplate RPM, without raising the voltage?
Ozzie
ger21
Global Moderator
Offline Offline
View Profile WWW
« Reply #1 on: March 01, 2011, 06:03:24 PM »
A servos rpm is proportional to voltage. I don't think the motor would last long, if you provided more voltage than it's rated for. I've read that you really should design to run at 80% of the rated rpm.
The Smoothstepper just sends step and dir signals, and can only have it go as fast as you have your motor tuning set.
Pages: 1   Go Up
Print
Jump to:
