May 27, 2012, 04:56:22 PM
Search:     Advanced search
+  Machsupport Forum
|-+  Mach Discussion
| | |-+  feed speed
Pages: 1   Go Down
Print
Author Topic: feed speed  (Read 197 times)
gmccorkill
Active Member
Offline Offline
View Profile
« on: March 01, 2011, 07:31:16 AM »
Is there any way to speed up feed beyond the overide?Even using the max override machine is still slower than i think it can go
Active Member
Online Online
Carnoustie, Scotland
View Profile
« Reply #1 on: March 01, 2011, 07:41:14 AM »
Feed is commanded with the F word in your code, so for example if you had G1 X10 F100 it would move at 100 units per min.
Overloaded
Global Moderator
Offline Offline
View Profile
« Reply #2 on: March 01, 2011, 07:45:53 AM »
adding to Hoods ... FRO only goes to 300%  of commanded feedrate.
If you want to go faster than that, and the max speed in motor tuning will allow, you'd have to increase the F feedrate in the code.
"I haven't failed. I've just found 10,000 ways that won't work."         Edison
"You cannot help men permanently by doing for them what they could and should do for themselves."
Abe Lincoln
Pages: 1   Go Up
Print
Jump to:
