Hello Guest it is June 11, 2026, 11:46:07 PM
Author Topic: Latest version and updating  (Read 16023 times)
« on: February 27, 2011, 08:31:16 PM »
I bought Mach couple years ago and for several reasons wasn't able to use it.  In Help/About mine says Version D1.90.050.
I'm pretty sure this has been updated.  What is the best way to update, I didn't see an option in Help or File?
Steve.
Re: Latest version and updating
« Reply #1 on: February 27, 2011, 09:50:57 PM »
Go to the download tab and select Mach and Lazycam
The latest version is  R3.043.022
Jeff
« Reply #2 on: February 28, 2011, 10:01:21 AM »
That was easy, except now the program shows "demo" instead of "registered."
Do I need to email or call someone?
Steve.
« Reply #3 on: February 28, 2011, 10:08:14 AM »
Did you buy a licence? If so you should have an email that contains the licence file, simply place that into the Mach3 folder and start Mach and it should be licensed.
andrewm
« Reply #4 on: February 28, 2011, 10:20:40 AM »
If you no longer have the license file you can contact license@machsupport.com and request it to be resent. You will need to provide your full name and email address used to purchase the license.
« Reply #5 on: February 28, 2011, 10:32:24 AM »
Thanks everyone, I am now legitimate!
AndrewM - It took a little searching in email, but I found the file.
Maybe for Mach4 they could consider an update link in the Help tab.
Steve.
« Reply #6 on: February 28, 2011, 10:39:05 AM »
Normally you will have nothing to do when updating and I dont know why you lost the licence unless you deleted the Mach folder before you updated?
« Reply #7 on: February 28, 2011, 10:44:24 AM »
Hood - You caught me.  By mistake I installed the update at c:\ instead of c:\programfiles\ where the prior version was.
Steve.
« Reply #8 on: February 28, 2011, 10:47:40 AM »
As long as you are up and running again thats all that matters but I like to keep a backup of the licence, my xml, brains, screens, macros etc just in case my drive takes a dump.
« Reply #9 on: February 28, 2011, 10:59:32 AM »
C:\Mach3 is the default location. You had the old version in the wrong place. :)
