Hello Guest it is June 10, 2026, 02:36:46 AM
Author Topic: Mach 3 servo  (Read 9484 times)
Mach 3 servo
« on: February 20, 2011, 10:11:50 PM »
can someone please help!!! Just received 2 Gecko drives G320X DC servo drive from Kelinginc all is wired up and ready to run but for some reason the codes aren't going to the motors to turn. can someone please configure the setup. Thank you in advance.
Re: Mach 3 servo
« Reply #1 on: February 21, 2011, 02:05:22 AM »
Could be almost anything, have you got the correct port address set? Have you got the correct pins set for the motors? Have you got the Jog Control enabled? Do you need an enable for your breakout?
Re: Mach 3 servo
« Reply #2 on: February 23, 2011, 08:40:03 AM »
5V Power Supply for Breakout Board , 110V input
Variable AC Output Transformer MAX.20A TDGC - 2KM:
1 PCS Geckodrive Servo Motor Drive G320:
C10
KL34-180-90 (NEMA 34) Dual Shaft
US Digital: E5S-500-250-EG-PKG2
CA-3131 connecting cable
KL- 7220 72V/20A
This is the setup that i have. All the ports and pins are set. any help would be great thank you.
Offline thosj
  •  542 542
Re: Mach 3 servo
« Reply #3 on: February 23, 2011, 04:26:55 PM »
You have a CNC4PC BOB and Kelling stuff. Go to Keling's site and read thru their setup doc. CNC4PC has many usefull docs, too.
If we're going to help you here, we'd need a LOT more info on what you have setup and what you've done so far. LOTS MORE! Start with Mach docs, Keling docs, and CNC4PC docs and single step your way thru the entire setup from configuring the parallel port to ports & pins, and enabling the bob and all sorts of stuff.
Oh, and one thing, US Digital encoders require a DIP switch on the G320X's to be set. One post you said G320, one G320X, so we're confused.
Tom
