Hello Guest it is June 13, 2026, 09:07:28 AM
Author Topic: Mach3 slows down with large gcode file?  (Read 16333 times)
« on: February 19, 2011, 08:18:35 AM »
Hi all,
I was doing some tests the other day, where i was using aspire to generate some gcode, with very small step overs.  This resulted in gcode files which had something like 400,000 lines of code or so....
Anyway, decided to load them into mach for some test cutting, and when i did that, the program became very sluggish and slow...when i began to jog my machine with this code loaded, i would hit say the x jog button, and the machine would respond 3 seconds later...
Is there some sort of a hard limit on the size of gcode, or maybe i need more memory or something?  Computer is a 2.4ghz machine, with 2gb ram, running a very stripped down version of windows xp...basically completely dedicated to mach..
Unloading the large gcode file, returned things to normal...
Any input or suggestions?  Has anyone else seen this?
Re: Mach3 slows down with large gcode file?
« Reply #1 on: February 19, 2011, 09:17:26 AM »
Turning off the Toolpath view will help, think its settings page.
Rev 4 of Mach should be a lot  better, when it will be released is anyones guess as Brian keeps getting hauled away to fix problems in Rev3.
« Reply #2 on: February 19, 2011, 11:42:04 AM »
It's related to the way Mach3 displays the toolpaths. I just turn the toolpath off if I'm over 150,000 lines of code.
« Reply #3 on: January 26, 2016, 06:03:18 AM »
I read your discussions and I have the same problem of large file. Wich is the maximum dimension il lines of a g code that Mach3 can run?
Please HELPP!!
Pietro
  •  9,356 9,356
« Reply #4 on: January 26, 2016, 06:19:22 AM »
Mill & Plasma: 500 line gcode limit (10,000,000 limit after licensing)
Turn: 50 line gcode limit (10,000,000 limit after licensing)
« Reply #5 on: January 28, 2016, 04:08:51 PM »
turn your view port off especially if you have onboard graphics.
I have run millions of lines of Gcode through mach3 no problem.
