Hello Guest it is June 09, 2026, 07:06:06 AM
Author Topic: how to config z axis HCNC  (Read 12928 times)
« on: February 18, 2011, 03:03:47 PM »
how to config z axis HCNC? do I need to program all  fractions or is there a way to set it up properly?
Re: how to config z axis HCNC
« Reply #1 on: February 18, 2011, 03:08:30 PM »
Dont really follow what you are meaning, can you expand a bit?
« Reply #2 on: February 18, 2011, 03:11:37 PM »
HI hood. I m using the program in Mach3 instructions where each axes is run 50 times
but when I get to z axis I need to enter fractions of a n inch to run within the throw of the
z on the hcnc machine.
« Reply #3 on: February 18, 2011, 03:45:48 PM »
Sorry, still not following, what is hcnc?
« Reply #4 on: February 18, 2011, 04:49:22 PM »
hcnc is Hobbycnc
« Reply #5 on: February 18, 2011, 05:01:23 PM »
Ok so its a mill or router? I am thinking you are maybe meaning that when you command a move of 1 inch its moving much more?
If thats the case then your steps per unit are wrong, quick and dirty way to set it up is use the Set Steps Per button on the settings page and run through the procedure. That will however only be as accurate as your measuring. Proper way is to calculate, for example if you know if the stepper is 1.8 or 0.9 degrees, what microstepping your drive is, what gearing is between scre and motor and lastly pitch of screw, then you canwork it out.
« Reply #6 on: February 19, 2011, 05:24:19 AM »
its a router and the z movement is small. 1 inch is a full move so to move z ha;f way I need to enter z-.5. Is this the way its done?
Al
« Reply #7 on: February 19, 2011, 05:27:53 AM »
If you are saying the full travel is 1 inch and when you ask it to move 1 inch it does, then that is correct, you will need to always have decimals as moves.
