May 27, 2012, 03:48:35 PM
Search:     Advanced search
+  Machsupport Forum
|-+  Mach Discussion
| | |-+  AUTO 0 Z-AXIS HELP ???
Pages: 1   Go Down
Print
Author Topic: AUTO 0 Z-AXIS HELP ???  (Read 384 times)
tomvision
Active Member
Offline Offline
View Profile
« on: February 16, 2011, 03:22:50 PM »
Can somebody help?  How to create auto 0 Z axis program in Mach3.  I am new in forum and just switch from shopbot to Mach3, I would like to have auto 0 z axis program as C2 file in shopbot controller I have been used for years.  All help would be appreciate,
Tom,
Overloaded
Global Moderator
Offline Offline
View Profile
« Reply #1 on: February 16, 2011, 04:04:51 PM »
Do you mean like a touch plate to set the work 0 ?
If so, do a search, there's gads and oodles of info and examples.
If not,  ? ? ? ? ?
Rc
"I haven't failed. I've just found 10,000 ways that won't work."         Edison
"You cannot help men permanently by doing for them what they could and should do for themselves."
Abe Lincoln
tomvision
Active Member
Offline Offline
View Profile
« Reply #2 on: February 16, 2011, 04:12:24 PM »
The program auto 0 Z-Axis.  What I want is, the Z-Axis come down touch metal plate (Grounded) then back up and go down again to touch plate and go back home.
Thank you for help,
Tom,
Overloaded
Global Moderator
Offline Offline
View Profile
« Reply #3 on: February 16, 2011, 04:31:33 PM »
Tom,
  Here is one of many topics.
http://www.machsupport.com/forum/index.php/topic,12633.0.html
Abe Lincoln
Overloaded
Global Moderator
Offline Offline
View Profile
« Reply #4 on: February 16, 2011, 04:39:20 PM »
another good one,
http://www.machsupport.com/forum/index.php/topic,12980.0.html
Abe Lincoln
tomvision
Active Member
Offline Offline
View Profile
« Reply #5 on: February 16, 2011, 05:09:01 PM »
Thank you very much for your help.  I will follow those links and start from there,
Tom,
ger21
Global Moderator
Online Online
View Profile WWW
« Reply #6 on: February 16, 2011, 07:28:02 PM »
http://www.cnczone.com/forums/cnc_wood_router_project_log/36099-another_aussie_auto_tool_zero.html
http://www.cnczone.com/forums/mach_wizards_macros_addons/100594-mach_3_tool_setter_big-tex.html
Pages: 1   Go Up
Print
Jump to:
